front poly bushings
Old Dec 19, 2001 | 05:06 PM
silver & red CE's Avatar
silver & red CE
Default front poly bushings
I'm considering replacing the bushings on my front suspension with poly bushings. Which points should I replace:
Upper and lower A arm bushings (I already have poly in the lowers thanks to the Z51 option)
Rack and pinion bushings
Upper shock bushings
Eric
Old Dec 20, 2001 | 08:28 PM
silver & red CE
Default Re: front poly bushings (silver & red CE)
Any ideas?
Old Dec 20, 2001 | 11:52 PM
lemans396's Avatar
lemans396
I just recently finished my suspension rebuild. Among other things, I replaced
upper/lower control arm bushings, sway bar bushings and sway bar end links with polyurethane.
Old Dec 20, 2001 | 11:53 PM
lemans396's Avatar
lemans396
Default Re: front poly bushings (lemans396)
Oh yeah, shock bushings too.
Old Dec 21, 2001 | 10:20 AM
h rocks's Avatar
h rocks
Eric, your car may have slightly higher durometer rubber bushings in the lowers from the factory, but not poly. The areas mentioned in your post are good ones to change over. If you ever get ambitious, replace the diff carrier bushing with poly. It *will* tighten up the whole car. You will immediately notice improved steering response.
To front poly bushings
