Easy Electrical Question
Old Dec 19, 2001 | 05:27 PM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default Easy Electrical Question
I installed a switch on my power antenna wire from my head unit (aftermarket pioneer CD player). I tried it a couple of times and it worked! BUt then it blew the inline fuse! Why? if i just replace the fuse will it just happen agin. I checked all my sodering points and they were all ok and covering in duct tape. Any help is greatley appreciated.
From
Will
1984
PS
could my switch be rate for too many amps? I checked the switch in my house witha light bulb and battery and the switch is still good.
Old Dec 19, 2001 | 05:52 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: Easy Electrical Question (flyinace2000)
A little more detail please... how did you hook it up.. by simply breaking the line coming from the radio and putting a SPST switch in it or some other way?
Old Dec 19, 2001 | 05:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Heat shrink tubing is the prefered method on electrical splices.
Replace the duct tape with black electrical tape, double check your wiring and try a new fuse.
Old Dec 19, 2001 | 07:39 PM
dtorc4's Avatar
dtorc4
Your antenna my simply be requiring too much power for the fuse. Hook up a multimeter to the line and see how much power it is drawing. You may simply need a larger fuse. Really, the main purpose of a fuse is to prevent the wire from shorting out and catching on fire. Adding a larger fuse (but not too much for the wire) will not hurt the charging system or electronics. :cheers:
Old Dec 19, 2001 | 07:45 PM
flyinace2000
Thanks Guys
I went down to radio shack and got set of .5amp fuses to replace the blown one. But this time i got short blow fuses instead of fast acting ones. And now it works perfectly. Antenna goes up when i tell it and down when i tell it! Ahh another job done :-) and all for under 5 dollars. Doing work yourself is great.
From
Will
Old Dec 19, 2001 | 11:02 PM
LT4CEZ51's Avatar
LT4CEZ51
Default Re: Easy Electrical Question (dtorc4)
Replacing the fuse with a larger one is a great way to fry the deck. The power antenna lead off most head units (especially aftermarket) is a transistorized output. It is designed ONLY to actuate a relay. They really don't like to put out more than about 200mA of current. I am glad switching to a slow-blow fuse worked.
Ted
96 CE LT4 Z51
Old Dec 19, 2001 | 11:44 PM
rafzz4's Avatar
rafzz4
yeah you would think by now that all these cool aftermarket radios would have a button for the antenna. :cuss
Old Dec 20, 2001 | 04:08 AM
merrick's Avatar
merrick
I hope you put a relay in there. The antenna motor will draw a few amps.
Old Dec 20, 2001 | 12:10 PM
Wildride's Avatar
Wildride
Duct tape is BAD NEWS when used with electrical wiring. It will eventually dry out and start falling apart and/or the adhesive will dry out over time and the tape will separate from the wiring. Either way your wires will be exposed and possibly short out.
I wont even use vinyl electrical tape because of the adhesive situation in "permanent" installations. Use shrink tubing on your connections and avoid the problems.
Old Dec 20, 2001 | 05:32 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Easy Electrical Question (Wildride)
See the same post in the audio section for more details.
To Easy Electrical Question
