thanks for all in put on hypertech
Old May 27, 2008 | 08:39 PM
nickpe's Avatar
nickpe
Default thanks for all in put on hypertech
chip. I will not use the chip. the 1.6 rockers are the best bang for the buck. the exhaust rates second.next ill try the AFPR thanks again
Old May 27, 2008 | 08:48 PM
Aardwolf's Avatar
Aardwolf
You can try playing around the the AFPR, but probably won't find much. Have you thought of removing extra weight? Intake?
Old May 27, 2008 | 10:07 PM
nickpe's Avatar
nickpe
Default no
will injectors help
Old May 27, 2008 | 10:10 PM
Aardwolf's Avatar
Aardwolf
Originally Posted by nickpe
will injectors help
If your HP has not gone way up, higher flowing injectors wouldn't help. If your stock injectors are damaged then gains could result from correct operation.
Digging into the rockers was a great idea. Have you thought of a cam?
To thanks for all in put on hypertech
