Hurst Shifter installation
http://forums.corvetteforum.com/show...hlight=shifter
Larry
PS - you may want to get a shorter shift boot - I got mine from RedlineGoods here on the forum.
It is a pain and should have been stock.
I also got a cool shift **** from Flameball.com
Cheers
Check your 6
Cheers
Check your 6
The shifter install is EVIL!!! Deninitely not for the faint of heart. I dropped the exhaust but still have it connected on the passenger side although it is slid back for clearance. I used a large rubber mallet and administered the beating
to get it to move and have enough clearance for my big hands.I wound up going off island for two sizes of long lineup punches by Mayhew Tools (Made in USA)
I got 1/4 and 5/32 sizes at the Oreilleys Auto on the other side of the ferry in Aransas Pass. I was able to drive the pin out using the new punches and a 3 pound sledge. I finally have the shifter mechanism installed. I need to get the pin in just a tiny bit more so I can slide the snap ring retainer back into place. Getting the shifter linkage back on the transmission was a chore. I did flip the link when I installed the new billet shifter so I am driving up to replace the pin. I don't see how you could install it and drive the pin from the top. The instructions seem vague here.The inner boot in the console was real fun to install too. I'm using a new one and installing it with the console structure in place is also challenging. I nudged the boot on from above and below. Lots of time spent wiggling and prodding and I didn't tear or rip it.
I still need to reassemble the console (door lid and shifter plate) , install the ****, move the snap ring back underneath and tie the lower boot back up. Then bang the exhaust back into place and bolt it back up. If I punt and finish tomorrow it won't matter. I have most of the evilness finished.
I was using a small pin punch at first and going no where fast. Once I got the big alignment punches (they are quite long) I had the pin out in 10 minutes.
I guess this is another rite of C4 ownership. Only those who have suffered installing a new shifter - either Hurst or B&M - KNOW MY PAIN
Is there anything easy to do on these cars?I need to install a new rear aux brake light and I understand that is a real fun one too.
Larry
Larry
Cheers
