spark plug prices..grrr
Old May 29, 2008 | 06:01 PM
94admiralblue94's Avatar
94admiralblue94
Default spark plug prices..grrr
Autozone wanted 7 bucks each for AC's and 8 bucks each for ngk tr-55's. Thats over 60 bucks for plugs!!!!
I thought that was high. I only drive this car a few thousand miles a year. Its a 94 with 30,000 miles.
Would you guys please list the type and price of the plugs you use and wires? So I can compare and contrast. If I find something online, I'm just going to order.
I would really appreciate it. I didnt check any other store yet. Hell, I might even go with the champion plugs. They were only a few bucks each.
Thanks!!!
Old May 29, 2008 | 06:06 PM
c4sailor's Avatar
c4sailor
I have MSD 8.5mm Super Conductor wires on mine. Got through Summitracing.com Haven't bought plugs recently so can't help there.
Old May 29, 2008 | 06:23 PM
94admiralblue94
c4, thanks for the reply. I just found some autolite single platinum AP106 plugs for 2.79 each. I'll probably go with those and the Bosch Wires, or the Bosch Platinum plus plugs 4005, for 2.99 each.
Old May 29, 2008 | 06:25 PM
LT1 Spirit's Avatar
LT1 Spirit
I bought a set of Bosch Platinum IR Fusion and the gap is not adjustable. for 68.00 I did not install them yet so I dont know how the work
Old May 29, 2008 | 06:35 PM
Aardwolf's Avatar
Aardwolf
You don't need to waste that much money on expensive gimmick plugs. I use the standard $1.95 AC Delco plug in mine. Also I used Taylor wires from Summit racing.
Old May 29, 2008 | 07:28 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Why would you even want to mess with them? The set you have will last~100k.Same with wires. At 30K you do not need to be messing with them and will see no difference except mabey for the worse. Bad things can happen when you start changing things that do not need it.
Old May 29, 2008 | 11:09 PM
94admiralblue94
sorry guys,
I didnt mention I took out a few of the plugs and they were black. Actually, you can scrape the carbon off with your fingernail. I think it might be from slow driving and not driving at all. No check engine light came on. After I get them all out, I'd like to post pics of them.
Old May 29, 2008 | 11:30 PM
JonnyAngle's Avatar
JonnyAngle
AC Delco all the way. Especially if it's a DD. There's no way a "better spark plug" will give you any noticeable difference.
Old May 29, 2008 | 11:34 PM
lltrevino's Avatar
lltrevino
Old May 30, 2008 | 12:24 AM
PurtyLilC4's Avatar
PurtyLilC4
I prefer NGK plugs myself, just the regular $1.98 ones, and a nice set of 8mm wires
Old May 30, 2008 | 12:33 AM
JimiHendrix's Avatar
JimiHendrix
I can feel the difference when I have bosch platinium plugs. Esp at the low rpms. But the effect goes away after a few thousand miles. The ignition on the LT1 is so hot that it probably doesn't matter over the long haul anyway. I stick with the inexpensive AC delcos.
Old May 30, 2008 | 12:34 AM
JimiHendrix
What do the 8mm wireset cost you?
Old May 30, 2008 | 01:17 AM
PurtyLilC4's Avatar
PurtyLilC4
the set of Mallory wires I'm currently running cost me about $60
Old May 30, 2008 | 01:21 AM
93lt1fun's Avatar
93lt1fun
I just bought some NGK TR6's for less than $2 each at Advanded Auto Parts. Go with MSD 8mm wires. I buy most of my performance parts, and you can get plugs from Summit Racing.
Old May 30, 2008 | 02:44 AM
geist's Avatar
geist
Isn't part # 3951 the regular vpower NGK TR55?
Autozone has them for $2.09
http://www.autozone.com/R,APP52535/v...ductDetail.htm
Maybe you were looking at the iridium TR55-IX, part # 7164 at 7.99
Old May 30, 2008 | 05:06 AM
Weav's Vet's Avatar
Weav's Vet
[quote=Redeasysport;1565671384]Why would you even want to mess with them? The set you have will last~100k.Same with wires. At 30K you do not need to be messing with them and will see no difference except mabey for the worse. Bad things can happen when you start changing things that do not need it.[/quote]
How true that is!!!
Got a Interstate close by? Just get on it and run about 80 for 20 or 30 miles. That'll help clean it out some. Unless it's skipping I'd leave it alone.
Old May 30, 2008 | 10:59 AM
NEVRL8T's Avatar
NEVRL8T
And I use TR55's.
To spark plug prices..grrr
Old May 30, 2008 | 11:03 AM
rickneworleansla's Avatar
rickneworleansla
I'm also using the NGK's except the TR6's for nitrous. They are good plugs and cost around $2 each. If you don't change your own plugs I would learn and swap them out every year or two. I'm using MSD 8.5mm wires but you will have less trouble fitting the taylors.
Old May 30, 2008 | 11:10 AM
SunCr's Avatar
SunCr
Absent some obvious ignition problem - why change the plugs? Design compensates for wear meaning that fuel delivery will be adjusted to maintain the proper air/fuel ratio. If it's running rich, you may have something else going on and you should scan it to find out. If it turns out normal, you're wasting your time and money. Buy yourself a scanner or get some free software and use a laptop.
Old May 30, 2008 | 11:26 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Huh??????
I know I didn't spend $60 for my NGK's a few months ago. IIRC they were $4 or $5 each. I probably got them from summit with my wires and other parts.
Just bought Autolite platinums for the FORD the other day, they were $3 each. Replaced a set of bosch platinums in that car. I was dissapointed in how long the lasted, less than three years and a lot less than 60,000 miles. Had intermittent misses on 2 cylinders in that car. I won't buy them again.
