tilt steering problem
Old May 30, 2008 | 04:22 PM
tombueh's Avatar
tombueh
6th Gear
Default tilt steering problem
is the tilt assembly suppose to be loose where it bolts to the column? i have tightened the bolts as tight as i could frearing i will twist them off. i can still move the tilt mechanisum about an 1/8" where the bolts attach at the base.
by the way does anyone know if the all 94's came with keyless entry? i didnt get a remote when i bought the car.
Old Jun 1, 2008 | 07:59 AM
coors2003's Avatar
coors2003
wow i cant believe nobody here knows anything about this
bump TTT
Old Jun 1, 2008 | 10:35 AM
TA's Avatar
TA
Your problem is likely not the bolts which you tightened. My understanding is the tilt mechanism has some type of a pivot pin that sits in a metal bushing. The hole in the bushing becomes elongated over time cause the play in the column. You need to press out the old bushing and install a new one to correct the problem. I've never had mine apart, but I do have the same issue so I'll need to do the repair at some point. I think if you do a search you'll come up with many threads on the topic.
Old Jun 1, 2008 | 10:46 AM
2012 coupe's Avatar
2012 coupe
Default Tilt problem
You can get a kit from the dealer or where ever to fix the problem. There are two different type of wheels on the C4, hence 2 different part #'s. they have new spring and bigger pins in them.
Old Jun 1, 2008 | 01:07 PM
Red Dwarf's Avatar
Red Dwarf
PKE is standard starting with 93.
To tilt steering problem
