MPG WAY down : (
Old Dec 20, 2001 | 02:10 AM
Jsailor24's Avatar
Jsailor24
Default MPG WAY down : (
All of a sudden my mpg is from 21-24 being nice to 16.5 being nice. What could've happened? No codes, no nothing, just low MPG. Thanks. :cheers:
Old Dec 20, 2001 | 03:58 AM
merrick's Avatar
merrick
Default Re: MPG WAY down : ( (Jsailor24)
Try changing the oxygen sensor and hope for the best.
Old Dec 20, 2001 | 10:19 AM
Goody's Avatar
Goody
I've noticed the same symptoms on my 93. I had a halfshaft ujoint go bad and replaced it, but mileage still has not improved. May have another problem. Gotta do more research before I buy parts. :U
Old Dec 20, 2001 | 10:28 AM
maduraj's Avatar
maduraj
Yep, thats what I heard. If your gas milage suddenly goes down with no codes or any other problems, it most probably is the oxygen sensor.
Old Dec 20, 2001 | 10:29 AM
dtorc4's Avatar
dtorc4
Check you spark plug wires. I had the same thing happen to me, a plug wire melted through b/c it was touching the exhaust manifold. I too got about 16 mpg hwy. When I replaced it, it went up to 24.5. It did not set any codes, but it did run like it was missing. Check plugs too, you might have one that is gunked up. :cheers:
Old Dec 20, 2001 | 08:23 PM
dmalhi1's Avatar
dmalhi1
hmm i got same problem
found one of the o2 sensors were mucked up replaced it but haven't taken the car back onto the hwy since to do a run and see where the fuel averages out right now it says like 12-13mpg! thats insane! lol
To MPG WAY down : (
