Temp Control Slider Problem
Old May 30, 2008 | 08:36 PM
Whipman's Avatar
Whipman
Default Temp Control Slider Problem
Hello All,
The temperature control slider on my 85 was very hard to slide from cold to hot. The control finally broke. I pulled it apart, repaired the slider, lubed (with cable lube) and checked the cable. All was fine. Worked perfectly. After re-assembly (correct cable routing, proper adjustment etc.) it's hard to slide again. Has anyone else had this problem? Any suggestions / answers greatly appreciated. Thanks in advance..........Whip
