Is an LT1 externally balanced?
Old May 30, 2008 | 09:10 PM
TBH94's Avatar
TBH94
Default Is an LT1 externally balanced?
My question is that simple. Is it externally balanced? I have heard that LT4's are externally balanced.
I ask the question because I have a slight vibration in my butt at 3200 rpm and higher. I think it is in the clutch. I guess it could be a ujoint. But the throw out bearing is noisy so I think I will do the clutch. When I do the clutch, should I do a flywheel?
Thanks in advance for any info.
1994 Admiral Blue 6 speed.
Old May 30, 2008 | 09:35 PM
rodj's Avatar
rodj
1 piece seal crank engines ( late L98 . LT1 , LT4 , ZZ4 ) are neutral at front and external at rear.
The bolt pattern to crank (PCD ) is also smaller than internal balance flywheels.
Old May 31, 2008 | 10:43 AM
TBH94's Avatar
TBH94
Does anyone know how to balance the flywheel? Is there markings you can check? Does it have to be balanced to the engine?
Old May 31, 2008 | 12:10 PM
STL94LT1's Avatar
STL94LT1
A new flywheel needs to be match balanced to the original.
Old May 31, 2008 | 01:18 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I would not mess with the flywheel unless you find a problem with it. I doubt your problem is that.What STL94LT1 said is true if you swap it you need the old one to balance it.
To Is an LT1 externally balanced?
