GN turbo
Old Jun 8, 2008 | 03:25 PM
  #61
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Mojave
More specifically, they have the FWD 3.8L heads, which are more narrow, and allow it to fit inside the shock towers.
Actually they're from a 3.0L V6. The GNX motor is 3.8L.
Old Jun 9, 2008 | 12:11 AM
  #62
Buick231's Avatar
Buick231
If you ever turn up the wick on the GN motor youll need to upgrade the bottom end also., namely the rods.
Not even close. 550rwhp is easily attainable on the factory stock bottom end and many have pushed in excess of 600rwhp and 650lbs. The rods are fine. When the power limit is exceeded, the crank gets pushed out of the block. I run a girdle to hopefully keep it together a little longer with the stock block, rods, and crank. 602hp and 620lbs for a few years now without a problem. Idles and drives like a stocker. Methanol injection enables this power on 91 octane.
Old Jun 9, 2008 | 12:18 AM
  #63
Buick231's Avatar
Buick231
Originally Posted by DarkBlue88
From experience of currently owning both an 86 GN and an 88 C4, I wouldn't do the swap. The turbo lag would drive a C4 owner nuts, and yes it would get worse mileage. I can't pull down 20 mpg with mine, and it's mostly stock. Not to say that I don't enjoy the car, it just kind of belongs in a Buick.
The GN motor isn't as kind to the driver as a TPI motor, you have to kind of time the throttle just right, too much at the wrong time and it'll respond slower, it's finicky like that.
True 4 years ago. With the new DBB turbos, lag is a thing of the past. I'm running a 9 second capable turbo with a tight 2,800 stall convertor and it hits 25psi in about a second. Years ago it would've required a 3,800 stall and would have been lazy and no fun on the street. If I had a smaller turbo capable of "only" 11s, boost would be instant. Turbo technology has come very far in only a few years.
I totally understand the advantages of the NA motors, just trying to set a few things straight.
