Driving it back from the shop from a tune and a new ECM was needed, my 93 just died on me in the middle of a busy intersection. Looking like a idiot, I pushed it into a parking lot where the car wouldn't start. Luckily after 5 minutes, it started up again and I was able to drive it back to the shop where DTC 42 was set. After shutting off, it wouldn't start at all. We tried an ICM from an LT1 impala and no luck, same symptoms. Opti is a MSD unit with less than 2000 miles on it. Service manual doesn't diagnose a bad distributor but faulty connections or faulty ECM. Could DTC 42 be a bad opti?
You might try to see if all the connectors are seated properly and check for broken wires at the harness. Seen more people break wires at the harness, because they pull on the wires w/harness.
Grounded knock sensor drawing down the 5V from the ECM
Why would a grounded or open knock sensor keep the car from running? I would expect it to keep running, put it into limp mode and turn on the check engine light.
aside from that, the ICM works off of CKT 423 at the ECM and the knock sensors on CKT 496. How can one draw more power from the other and set off an opposite code. According to the service manual, DTC 43 will set if more than 4.1 volts is drawn from the knock sensors, not DTC 42.
