MSD - Install problems - Help
Old Jun 1, 2008 | 08:50 PM
deerra's Avatar
deerra
Default MSD - Install problems - Help
I need a little help from my friends.
Trying to install a MSD opti and it won't slip in and seat. I know about not forcing it or using the bolts to tighten it down. I lined up the rotor with where the old rotor was and I rock the rotor back and forth slightly keeping the base square with the engine and she won't go.
I inspected the original shaft which seats just fine with the MSD shaft. They appear to be different.
I took some pictures - take a look.
The first pic is the original opti shaft. It appears to have a short spline down the middle.
The MSD is a broad shoulder.
What do you think????
Old Jun 1, 2008 | 09:42 PM
jim_hewett's Avatar
jim_hewett
Default Got the right one?
8481 for 93-94 & 84811 for 94-97....I'd call MSD techs @ 915-855-7123...you've got a 92 right? Might have a retro fit for your earlier model.
Jegs shows it as 93-94 for F body & 92-94 Corvette specific, I'd still call MSD! You've been shafted!!!
Old Jun 1, 2008 | 10:09 PM
deerra's Avatar
deerra
This is supposed to be a 8381 which, according to MSD, fits the 1992. All I know is that damn thing won't install.
I can slide the original shaft in and out with no problem.
Old Jun 1, 2008 | 10:11 PM
jim_hewett's Avatar
jim_hewett
Might be a typo in their 2008 catalog(MSD)
Old Jun 2, 2008 | 12:54 AM
geist's Avatar
geist
Pretty sure if you got the wrong year you'd know it immediately... there is a big difference in the mounting of later optis, this page has some pics ttp://www.impalasuperstore.com/naisso/Forum2005/topic.asp?TOPIC_ID=30984&whichpage=1
Old Jun 2, 2008 | 08:16 AM
sonomacrew01's Avatar
sonomacrew01
do you have a digital caliper? That would be able to tell you the thickness of the teeth on the shaft. Before I switched to a 94+ style opti, I had purhcased one for my 93 and it took a couple of attempts to align the dial on the opti with the shaft.
Old Jun 2, 2008 | 08:32 PM
deerra's Avatar
deerra
Default Victory!!
I got my MSD installed this afternoon.
I was having problems finding the "sweet" spot and finally applied a little logic to the problem and it slide in like it was on viagra.
Still have the wiring to do along with the WP install.
Thanks to those that replied.
Old Jun 2, 2008 | 09:23 PM
pianoguy's Avatar
pianoguy
Glad to hear you got it sorted out!
Old Jun 3, 2008 | 03:45 PM
jim_hewett's Avatar
jim_hewett
I feel a lot better too...got a MSD going in tomorrow. Help stamp out that damn OS.... spread the word! Incidently, I'm told Viagra's only good for four hours.... that install must have been a real short enjoy!
Cheers
To MSD - Install problems - Help
