What's going on here???....
Old Jun 3, 2008 | 11:30 AM
jim_hewett's Avatar
jim_hewett
Default What's going on here???....
Everyday driver...143k on chassis, 12k on New Jasper and ZF 6 sp. installed last Aug. Naturally hoses & belts changed. Had 3 OS failures last 6 mos..only routine tire & battery changes 12yrs prior... trouble free.
Distributer Failures
1. 4 mos ago OS failure due to pin hole leak in TB hose & OS to coil harness plug separation..good reason.
2. 2 mos ago Jegs OS installed found defective out of box. Chinese anyone? Still like their sweet & sour pork w a side of fried lice.
3. another Jegs arrived, installed ops normal for 2mos. Give em the benefit of a doubt can't get enough.
4. Currently Jegs crap is being replaced w the famous MSD* Still trouble shooting for related deeper issues maybe i.e. thrown codes, coil, module etc., FP OK.
* Header gaskets replaced & 1.6 RR's installed prior to step 4. Harness & wires undisturbed. Valves carefully zero lashed statically TDC & @ idle. Don't believe these corrections contributed. Fresh out of the shop idled quietly and accelerated like a homesick angel....but then...
after 5 min test run, eng faultered @ speed 72mph. Couldn't get anything above 72 then died in front of the shop. No restart.
No doubt the "little red *****", has experienced many heat cycles @ 143K (brittle & rotten wiring)
Gents what's your best shot on this? Apologize for the windy rant just concerned.
Cheers
Check your 6
Old Jun 3, 2008 | 11:59 AM
Steve20's Avatar
Steve20
Not that I could offer any assistance here, but is a homesick angel fast or slow?
Steve
Old Jun 3, 2008 | 03:12 PM
jim_hewett's Avatar
jim_hewett
Steve
Mine was very fast and highly motivated!
Cheers
To What's going on here???....
