Strange Pinging up top
Old Dec 20, 2001 | 06:54 PM
TIMSPEED's Avatar
TIMSPEED
Default Strange Pinging up top
I dunno why, but my last vette did this too. It pings a little at WOT, at around 4600-5000 rpm. Any ideas? Should I set my timing back some? (Say if it's at 8º, should I set it to 6º?) Thanks!
Old Dec 20, 2001 | 06:59 PM
scorp508's Avatar
scorp508
Default Re: Strange Pinging up top (TIMSPEED)
Try 7, if no good, go to 6. It doesn't help that you have nothing better than what like 91 octane in CA either? You should shift before 4600 anyways.
Old Dec 20, 2001 | 07:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Timing is a good place to start if it's more than +6deg.
If you think it's the fuel try a can of octane boost.
A scan tool would tell you if the ECM is pulling timing on the first ping or two, as it should.
Check for any codes; a bad ESC would not let the ECM pull timing and you would hear ping.
You might try a 160 deg stat & aux fan sw to get the coolant temp down and reduce knock tendency; tie the aux fan relay input to the main fan relay input so both come on around the 160deg range (see C4 Tech Tip).
Old Dec 20, 2001 | 07:28 PM
AS84's Avatar
AS84
Default Re: Strange Pinging up top (65Z01)
another option would be checking your fuel pressure. Maybe the filter is a little restictive.
Old Dec 20, 2001 | 07:38 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Strange Pinging up top (AS84)
If it's not the typical stuff, it might be the problem one member here had with his 86... (BBA is his name) weak valve springs we're his problem.
[Modified by Springer's 95, 6:38 PM 12/20/2001]
Old Dec 21, 2001 | 12:07 AM
snaketr's Avatar
snaketr
Default Re: Strange Pinging up top (Springer's 95)
Get your injectors cleaned.
Old Dec 21, 2001 | 12:08 AM
snaketr's Avatar
snaketr
I know it sounds crazy, but I had two 85's that were horrible about doing this and that fixed them both. The timing was set a 8 degrees on both also.
To Strange Pinging up top
