TPI noise
Old Jun 4, 2008 | 12:15 AM
mdennymike's Avatar
mdennymike
4th Gear
Default TPI noise
Hello everyone, I have a 1987 corvette that has developed a clacking sound from the motor. I shut the motor off because I first thought that it was a bent push rod . I restarted the engine and tried to narrow down the sound and I noticed that it was coming from under the plenum area of the TPI. I shut the engine off to connect a fuel gauge and then tried to start the car. When I turned the key to run without starting the engine a loud clicking noise was heard and the fuel gauge went from 40 to 20 LBS. a few times and then stopped at 43 LBS and held at that pressure. I need your help with ideas on what the problem might be. thanks.
Old Jun 4, 2008 | 12:39 AM
Matatk's Avatar
Matatk
Sounds like a bad injector.
Matthew
Old Jun 4, 2008 | 01:18 AM
mdennymike's Avatar
mdennymike
4th Gear
Default TPI noise
I thought that it might be a broken injector. today I drove it and the noise was gone but it had a misfire. should I also check the regulator? thanks.
Old Jun 4, 2008 | 01:23 AM
geist's Avatar
geist
If you are shopping for injectors you should consider ditching the stock multecs... you can update to Bosch III for not much more than the cost of getting a set cleaned, maybe less if you have to buy another injector from a parts store too. Theres been so much talk on here that you don't even need to use the search function to find a ton of threads.
http://fuelinjectorconnection.com/sh...&productId=134
Just wanted to point that out in case Jon doesn't pop in before you waste money somewhere LOL
Old Jun 4, 2008 | 01:43 AM
mdennymike's Avatar
mdennymike
4th Gear
Default injectors
I've been on the fuelinjectionconnection web site quite often and they have the best prices for a set of injectors that I have seen anywhere. When I order new injectors that is where I will order them..
Old Jun 4, 2008 | 12:21 PM
Matatk's Avatar
Matatk
I wouldn't think that it's the regulator. If you get it where the FP drops again, try tapping on the injectors with a screwdriver and see if it starts firing again - then you have found the bad one.
Matthew
BTW - FIC has a great reputation and prices. When I replace mine I'll be getting them there.
To TPI noise
