WHY????????
Old Dec 20, 2001 | 09:11 PM
vettedreams's Avatar
vettedreams
Default WHY????????
Why do I have to hold the gas pedal w.o. to start the car? I just re-built the L98 in my '86 ragtop,bored 60 over,polished& ported for flow only stock heads,extensive porting of stock TPI system, saw it in earlier post and it does work, just very very time consuming. The first time that I cranked the car after rebuild I didn't have to touch the gas at all. But now after riding for awhile and re-cranking it I have to hold it w.o for the engine to start. Thanks for thew help.
Old Dec 20, 2001 | 09:37 PM
scorp508's Avatar
scorp508
Sounds like a flood condition from leaky injectors. Did you replace them?
Old Dec 20, 2001 | 10:28 PM
vettedreams
Default Re: (scorp508)
that's what i was afraid of I'm also afraid of the replacement cost of those injectors. thanks for the input.
Old Dec 20, 2001 | 10:36 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
:yesnod: First place I'd look :yesnod:
Old Dec 20, 2001 | 11:31 PM
vader86's Avatar
vader86
Default Re: (mackeyred96)
doesnt a bad MAF cause hard starting also? just wondering
Old Dec 20, 2001 | 11:42 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Re: WHY???????? (vettedreams)
Hey , I will have some flow mathced 22#'s in week. You can try them out, and if you like them, we can sell your soul.. Just kidding. I will have mine out in a week from my 93 LT-1. They were flow matched by Callways people in CT. Let me know. I know 22#'s are not cheap (why I have no idea), and 24# Ford SVT's are around 210 new.
Old Dec 20, 2001 | 11:43 PM
steve40th's Avatar
steve40th
Default Re: WHY???????? (steve40th)
Good point, check your MAF. See if someone can switch with you , and run a scan "paper clip" and see if a code pops up, it may be intermittent and you wont get a check engine light.
Old Dec 20, 2001 | 11:47 PM
snaketr's Avatar
snaketr
When you first turn your key on you should here the IAC motor. If you do not than this is your problem. It is allowing no air into the engine and the cold start injector is enough to flood it. If you put in a new one make sure you push the pintle in before you screw it in or else you just ruined the new one.
Justin
Old Dec 20, 2001 | 11:54 PM
vader86's Avatar
vader86
Default Re: WHY???????? (snaketr)
id definitely get a shop manual (NOT HAYNES MANUALS) before i touched that IAC motor.
Old Dec 20, 2001 | 11:57 PM
snaketr's Avatar
snaketr
Default Re: WHY???????? (vader86)
More than likely this is your culprit. I have had many of these go bad. Save yourself the hassle and your labor, by a G.M. one, the ones from Advanced Auto, and the other stores don't last long.
Old Dec 21, 2001 | 08:43 AM
vettedreams
I hate to sound dumb, but what is IAC stand for?
Old Dec 21, 2001 | 09:22 AM
89vette's Avatar
89vette
Idle Air Control. It's located under the throttle body.
To WHY????????
