Oil Additive
Old Jun 5, 2008 | 07:08 AM
Roger anderson's Avatar
Roger anderson
Default Oil Additive
Is anyone running oil additive in their flat tappet car? I've been reading and hearing about a rash of lifter failures in non-roller motors due to the EPA reducing the amount of zinc and other additives in todays motor oils. After recently installing Edelbrock RPM heads on my car (86), I'm a little concerned with the added spring pressure (dual springs). I've been told add a bottle of Comp. Cams break in oil with the regular dino. oil. I'm a little hesitant to run Rottella, I've been told that it is not friendly to O2 sensors.
Any input?
Old Jun 5, 2008 | 10:46 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Synthetic oil, no additves
Synthetic oil does what additives claim would do
$7.49 per quart + oil filter = Good Maintenence
Old Jun 5, 2008 | 11:40 AM
Sidney004's Avatar
Sidney004
Any input?
The non friendly component is the zinc and phosphorus which is probably the primary additive used by Comp Cams. I am an Amsoil synthetic oil user in my street driven cars and Redline 10W-40 on my track driven LT1.
Old Jun 5, 2008 | 12:00 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I have always run Mobil 1 in my newer Corvettes 84-present with no engine related problems. I run the Rotella 15 W 40 in the older Vettes.
Old Jun 5, 2008 | 12:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I agree to just use a premium oil with no additives.
BTW, why do you feel the need for double springs with a no-roller cam??
Old Jun 5, 2008 | 12:38 PM
JAKE's Avatar
JAKE
CORVETTE ENTHUSIAST just ran a long article on camshaft failures caused by running today's engine oils. It's a REAL problem.
Pick up a copy; good reading.
Jake
Old Jun 5, 2008 | 12:47 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
STP contains ZDDP so I use that
Old Jun 5, 2008 | 04:19 PM
Roger anderson
I didn't feel the need for the double springs, i bought the heads used and got a good deal on them. I'm glad I got them, they sure made a difference in the seat of the pants department. I have been kicking around doing the retro-roller upgrade with next winters cam change, it just that the set-up is so dang expensive.
Thanks for the input guy's.
Old Jun 5, 2008 | 05:56 PM
Iroc57's Avatar
Iroc57
The zinc is needed for cam break in. After that you should be ok with whatever you feel like using.
Old Jun 5, 2008 | 08:25 PM
pletzvet's Avatar
pletzvet
In my higher mileage 85 L98 I've been adding the recommended proportion of Lucas oil stabilizer at each oil change using Mobil 1 synthetic. Does anyone know if it contains the zinc (similar to what was suggested with the STP) that has been eliminated in the SM API classification oils?
Old Jun 5, 2008 | 08:29 PM
89er's Avatar
89er
Any input?
Since all my engines run cool, I run dino oil. Then I add about 5ml of Triflow after each oil change. I buy it by the gallon which cost about $60 a few years ago. I advise against using it in an engine under 20K miles since it won't have the needed friction to break-in. I'm sure there will be skeptics - so add a little to the oil and feel the difference on the oil stick. Also I don't know if it's compatible with synthetic oil since I've never tried it.
http://www.triflowlubricants.com/Sup...rior_pump.html
Old Jun 5, 2008 | 08:54 PM
Chatman's Avatar
Chatman
I switched from Mobil 1 to Rotella for the zinc in my ironhead 86. I have heard the "not friendly to O2 sensor and catalytic converter" claim but have never heard anything measurable or factual. I suspect that it is BS or irrelevant. Pollution control equipment is supposed to last at least 100K miles. So maybe it only lasts 90K. Who knows. It probably does nothing but the manufacturer can't say that or the CARB people would be all over their butts because they forced oil for autos to remove the zinc.
Basically, use anything for diesel engines and you will be OK for lubrication.
Old Jun 5, 2008 | 09:06 PM
89er's Avatar
89er
I like Rotella too.
Government regulations/pressure presume that everyone is an idiot. Replace the O2 sensor every 50-75K miles and no worries. The nice thing about the '86 is it only has one O2 sensor.
I bought a box of O2 sensors for $13 each. I read somewhere that regularly changing O2 sensors will pay you back on fuel savings - and that was before the recent increases.
Old Jun 5, 2008 | 09:59 PM
Strick's Avatar
Strick
I think we need to get things straight here. Yes all the new oils (mobil 1 included) as of 2007 no longer have zinc and maganses additives in them. All the newer cars now have roller cams and don't need zinc and maganese. If you have a flat tapet cam, you need these additives for good cam life. Rotilla T has these additives and runs well in a flat tapet engine. Comp Cams also has an additive that contains these. Comp Cams won't warrenty a flat tapet cam if it doesn't have the additives. LT1s and LT4s are roller cam engines and Mobil 1 is just fine.
Old Jun 5, 2008 | 10:42 PM
89er's Avatar
89er
Less friction results in longer engine life no matter what kind of cam you have. The only gotcha is when the rings are seating you need friction. Since warranties are generally for the early part of engine life, there is little concern over how long it will last.
All of my cars have over 100K miles on the engines and none of them require oil between changes. I wouldn't use Mobil 1 if I could get it for free because of what it does to old seals.
Old Jun 6, 2008 | 07:40 AM
Roger anderson
Well, I bought a bottle of the comp. cams break-in additive to my recent oil change, then with the next oil change I'll use the Rotella. I've recently change my O2 sensor, so I should be golden with the rotella for awhile. I don't put a lot of miles on my car maybe 1,500 mile a year (weekend warrior).
Old Jun 6, 2008 | 12:31 PM
Steve20's Avatar
Steve20
Zinc and Phosphorous levels of SM motor oil have been lowered, from approximately 1200 ppm to approximately 700-800 ppm, because these levels are friendlier to the long life of the cat. Additional additives like calcium and boron have been added to address the lowering of Zinc and Phosphorous levels.
If you want to boost these levels back to the levels of SL rated oil, add half a bottle of GM Engine Oil supplement (EOS) which is used for new engine or cam break in. It was recently remformulated, but the product has been around for at least 35 years
To Oil Additive
