Coil grounding strap
Old Jun 5, 2008 | 02:55 PM
Rbuet's Avatar
Rbuet
Default Coil grounding strap
1995 LT1 - I think I am missing my coil grounding strap.
I recently removed the coil and do not remember seeing one, nor connecting one.
I recently had a no spark situation, replaced the ICM and it started. Two days later, back to the no-spark condition. Only code is DTC #12, which apparently tells me nothing. FSM seems to be pointing at an ignition ground problem.
Can anyone tell me what it looks like? Where it starts and ends? Do I have to purchase one? Or can I make one?
Thanks in advance for the help!
Ron
Old Jun 5, 2008 | 04:50 PM
DVNCI's Avatar
DVNCI
Ron
Pretty sure there isn't one, neither my 93' or 96' have one. The coil is grounded by the black wire that is in the harness itself I think.
I recently had no start with a Code 42 and after replacing ICM, Opti, and ECM it was the coil!!!!!!!!
Seems like Code 12 is just a burned out SES light if I remember correctly?????
Old Jun 5, 2008 | 05:18 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
DTC 12 says the ecm is communicating. If you don't get it you have trouble.
To Coil grounding strap
