Differential fluid?
Old Jun 7, 2008 | 05:21 PM
LS1 REDBIRD's Avatar
LS1 REDBIRD
Default Differential fluid?
What fluid do I need? 75w90 or 75w140
What brands have the additive premixed and where can I purchase?
2000 FRC 3.42 M6
Old Jun 7, 2008 | 05:53 PM
cyclerage23's Avatar
cyclerage23
redline lightweight shock proof 75/90
Old Jun 7, 2008 | 05:58 PM
cruisemon's Avatar
cruisemon
Any synthetic 75W90. Mobil1 is good. Buy the additive. Total for both will be about $15.00. O'Reilly, Advance, NAPA, Pep Boys, Autozone, any of them will have it.
Charlie
Old Jun 7, 2008 | 06:21 PM
LS1 REDBIRD
What type of additive? Will any parts store stock it or will I have to pick it up at the dealer?
Charlie
Old Jun 7, 2008 | 08:21 PM
rustyguns's Avatar
rustyguns
yeah this is the stuff to use i use 75/140 and it needs no additive! you will luv this stuff!
Old Jun 7, 2008 | 08:22 PM
rustyguns's Avatar
rustyguns
and its blue! looks cool !
Old Jun 7, 2008 | 08:46 PM
cruisemon's Avatar
cruisemon
Parts store will have the fluid, I think it's about 3 or 4 ounces, can't remember. But, it'll come in a small container, cost about $5.00. Mobil 1 is the OEM fluid and it has worked well for me.
Charlie
Old Jun 7, 2008 | 08:47 PM
cruisemon's Avatar
cruisemon
I thought 75/140 was dino and not synthetic.
Charlie
Old Jun 7, 2008 | 08:48 PM
cruisemon's Avatar
cruisemon
Mahse'f, I hope I don't see the color of my diff fluid.
Charlie
Old Jun 8, 2008 | 04:40 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Be careful, GM recommends GM Posi-traction add, (2) per complete change out, and Mobil 1 works fine w/additive. Gordon K specifically states that additive is needed.
Old Jun 8, 2008 | 05:10 AM
rustyguns's Avatar
rustyguns
it is already in the blend..it works great! too much additive and you lose posi traction!
Old Jun 8, 2008 | 07:05 AM
Strick's Avatar
Strick
I follow Gordon's advice and it works fine for me and my 92. GM axle fluid and 2 bottles of additive.
Old Jun 8, 2008 | 08:06 AM
pablocruise's Avatar
pablocruise
The OP states it's a 2000 C5.
Don't those cars have the getrag trans deal back there?
Old Jun 8, 2008 | 08:16 AM
Can86Z51's Avatar
Can86Z51
When I first changed out my 86Z51's diff gear oil(to Redline synthetic 75/90) about 12 years ago, I had similar questions about the additive? After speaking directly with the Redline tech guys, and several local Canadian lubrication engineers, all confirmed that no extra additive. incuding the GM additive, should be added, or rquired. From what I know to this time, most/all of the Synthetic gear-diff lubes have the proper additive(s) already included. Consult the oil manufacturer if in doubt! From what I've learned over the years, too much additive can cause problems too! Btw, I'm still using the Redline w/out additve extra, and no troubles on my 86 Z51. For what it's worth.
Old Jun 8, 2008 | 08:27 AM
ROB502's Avatar
ROB502
Default Rp
I use Royal Purple no need for any additives. Went that way in all my posi. Marauder, Vette, Jeep, Z71.
Old Jun 8, 2008 | 10:53 AM
Strick's Avatar
Strick
Sounds like we're getting into the "my source is better than your source" argument. Hey if your way works, stay with it.
Old Jun 8, 2008 | 11:01 AM
Can86Z51's Avatar
Can86Z51
Hey, thanks, I will! I/we were asked, in effect, our personal, direct knowledge and experience on this subject, and I gave it. Those who asked, can take it, or not, as they will. Ciao.
Old Jun 8, 2008 | 11:41 AM
96GS#007's Avatar
96GS#007
2000 FRC 3.42 M6
Might want to post this over in C5 Tech. I recall the C5 being different than all the C4 recommendations you're getting.
To Differential fluid?
