newbie, need some advice please
1: my rev counter is about 2k to high, not the engine, just the needle, its sits below 0 when off and when fired up and accelerating its just 2k higher than what it should be......
2. my check guages light comes on with ignition and goes out after few seconds, weird thing is that it very faintly flickers on when driving and on idle, bad earth possibly??
3 the car was sat for a while and when i drove it away the brakes were very faint with hard pressing and a wirring noise would come from the rear then service abs light, gradually that has stopped but what could that of been. still does it occasionally?
any help please, i have checked searchs but couldnt find much. thanks
and brakes are normally reliable then?
Hard brake pedal could be a vacuum leak to the power brake diaphragm, or a bad diaphragm itself. Is the brake pedal action the same way before you turn on the motor? If so, you have a vacuum leak, or bad booster.
Randy
Randy
Get the FSM - get the red two book edition (with electricals) though, not the preliminary white cover book. I'm not for certain, but the whirring noise you hear may be the ABS testing itself. I believe it is typical to hear it at the beginning of each drive. Good luck with your new vette,
Jonathan
