ps, chimer, where is it?
Old Jun 8, 2008 | 07:42 PM
louisjames's Avatar
louisjames
Default ps, chimer, where is it?
ps, the little chimer that sounds when a door is ajar or keys left in, i can barley hear mine atall. does any one know where the unit is located? im guessing a previous owner got annoyed maybe and put some foam over it to silence it. hopefully if i can find it i can fix it. thanks, ive ran a search but im not sure what you call it over there. thanks
Old Jun 9, 2008 | 01:33 PM
josephf31's Avatar
josephf31
Default what year>
In my '91 it's up under the driver's side of the dash, you have to remove both the carpeted panel and the metal knee bolster, then you will see a small black plastic rectangular box in a clip with a four-wire harness attached. This is not where the factory manual says it should be but that's where mine is. It's the same chimer for the headlights on, key in ignition, etc.
Old Jun 9, 2008 | 02:24 PM
louisjames's Avatar
louisjames
ok thanks, wher does the book say it is? just it sounds like its on passenger side.
Old Jun 10, 2008 | 12:55 PM
josephf31's Avatar
josephf31
Default for my 91
the manual says it's up behind and above the Driver Information Center.
Different years move components all over the place, unless you have a 90 or 91 I can't say for sure that's where it is...
Old Jun 10, 2008 | 01:15 PM
louisjames's Avatar
louisjames
its a 90
Old Jun 10, 2008 | 01:20 PM
jhammons01's Avatar
jhammons01
And the problem is??
I think, and this is just my opinion, that thing being quiet would be a selling feature for me.
Sorry I have nothing more to add, I don't know where that chime is.
Old Jun 10, 2008 | 03:04 PM
louisjames's Avatar
louisjames
lol
Old Jun 10, 2008 | 04:39 PM
Hooked on Vettes's Avatar
Hooked on Vettes
You need to remove the top dash pad to get to it.
Old Jun 10, 2008 | 05:41 PM
louisjames's Avatar
louisjames
thanks for that mate. excellent.
Old Jun 11, 2008 | 01:29 PM
josephf31's Avatar
josephf31
Default That's not where mine is
and my 91 manual has the same picture, mine is clipped to the underside of the dash to the right of steering column, no need to remove the dash pad but do have to remove the driver's side knee bolster and carpeting.
I have not idea if mine is factory location or not since the wiring is pretty messed up but that's where it is. Good luck.
To ps, chimer, where is it?
