Engine roars at start up.
Old Jun 10, 2008 | 05:32 PM
The Beep's Avatar
The Beep
Default Engine roars at start up.
Hi all,
On an 85 L98 4+3, when I start the car the engine turns over once and instantly roars to a very high rpm then backs down. With the flow master exhaust, anyone within 20 feet will soil their shorts.
No other car I know of does this. Is it normal?
Thanks,
the beep
Old Jun 10, 2008 | 06:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Remove the IAC motor and pintel from under the RH side of the TB and clean both pintel and its bore under the TB.
Then reset base idle; procedure on my site.
Old Jun 10, 2008 | 06:46 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
How long has it been since you were told your pintel was ickey!
Old Jun 10, 2008 | 09:51 PM
The Beep's Avatar
The Beep
Is this something a half-blind knucklehead would screw up and would actually be cheaper to have a real mechanic do?
I can do relatively simple things but as soon as it gets involved, I'm in trouble.
Old Jun 10, 2008 | 10:00 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Three days....
Aurora40's Avatar
Aurora40
The two C4's I've owned both start up at a higher rpm than they idle at. I think that's quite normal. How high are you talking about? I'm talking like 2,000 rpm max, but it sure sounds loud with a loud exhaust. Personally I like it.
Old Jun 10, 2008 | 10:51 PM
cwyates4's Avatar
cwyates4
Mine really roars at startup after its been sitting a while, and I too have flowmasters. On hot starts its more controlled, however.
I vote normal.
Old Jun 10, 2008 | 11:25 PM
Calderone's Avatar
Calderone
mine does the same
before i put my ****mufflers it was real loud like a shot !
or a big CLAP ! now with my mufflers its not terrible loud
USAsOnlyWay's Avatar
USAsOnlyWay
Mine starts, idles for a few minutes ~1200 rpm, then drops to idle.
What is a roar?
Old Jun 11, 2008 | 12:02 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default idle
mine does the same, except it's 800 RPM, then drops to 600 RPM.
I would expect that you have a vacuum leak, making the IAC ineffective, and the fuel management is relegated to the oxygen sensor, instead of the iac, throttle plates, and the O2 sensor. I am guesing the computer sees the position of the throttle position sensor, and reschedules the fuel.
for a minute there, I was afraid it was a white corvette forum.............
Old Jun 11, 2008 | 03:20 AM
86PACER's Avatar
86PACER
Mine growls on cold startup. I think the eliminators are the problem.
When I ran open headers, I was nervous to start it.
Seriously though, at what RPM does it rise to and how long does it stay there? What does it do on warm startups? It's normal for it to idle a little high on cold startups then gradually drop to spec idle after a few minutes of warm up. The TPI won't idle at spec speed right out of a cold start. Mine idles at about 1,200 RPM then drops to my 650 RPM setting.
Old Jun 11, 2008 | 07:38 AM
BADDUCK's Avatar
BADDUCK
for a minute there, I was afraid it was a white corvette forum.............[/QUOTE]
What's wrong with that?
Old Jun 11, 2008 | 11:03 AM
bczee's Avatar
bczee
White Corvette Forum (WCF).. I'm in.. LOL..
Mine starts up to about 12-13k and idles down to normal RPM (600-700) as expected.
Old Jun 11, 2008 | 01:34 PM
coupeguy2001
you can't find your um car in a snow storm
Old Jun 11, 2008 | 11:40 PM
The Beep's Avatar
The Beep
What is a roar?
It's like it floors the engine for about 1 second and then drops to normal. I can't do anything about it today because it's nothing but t-storms and tornados around here.
Gotta love white Vette's.
Old Jun 12, 2008 | 12:29 AM
USAsOnlyWay
Indeed!
Let us know how the IAC reset works.
Old Jun 12, 2008 | 03:18 PM
SunCr's Avatar
SunCr
I'd clear memory from the ECM first - at least in the old days, it was rumored that you could train it to give it this humbling little blast by simply goosing the throttle for a couple hundred startups. Eventually, it was suppose to burn that activity into memory and you wouldn't have to do anything. Pretty cool? Beats me, but all the youngsters were trying it. Otherwise, your ECM parks that IAC pintle at something like a 160 counts everytime you shut it down. That makes for a quick restart, but the rpms are going to be up there. Scan to see where yours is.
Old Jun 12, 2008 | 04:23 PM
65Z01's Avatar
65Z01
Check out the location of the IAC and its connector. Then scan over my writeup and decide if it's your next project or one for your mechanic.
To Engine roars at start up.
