Am I going to have any problems
Old Jun 10, 2008 | 07:39 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Default Am I going to have any problems
If I do this:
https://www.corvetteforum.com/techti...D=79&TopicID=2
I have a Hypertech lo-temp switch, and I'm running a 160 stat as is....
Old Jun 10, 2008 | 08:09 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you don't need to I wouldn't, you will burn out the main fan prematurely.
I turn on my aux. fan at 205 and that works fine. No need to run both fans early on my car.
Old Jun 11, 2008 | 12:59 PM
'Shifter's Avatar
'Shifter
NCM Member '09
I'm not worried at the cost of the fans that much (I know someone that sells them purty cheaply..:wink-but it does run pretty hot in Tucson, AZ traffic...
Old Jun 12, 2008 | 01:59 PM
'Shifter's Avatar
'Shifter
NCM Member '09
Old Jun 12, 2008 | 03:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I've been running that setup since I got my '88 in 2000 and had no problems with either fan so far.
The reason I opted for this method over a separate manual fan sw on the main fan only is the pure simplicity of the wiring.
I should mention that in this recent 80s-90s weather my fans run constantly and coolant temps range around 170deg F but then I'm running the std radiator, not the HD unit that came with the Z-51 option. And this is with the A/C Off; with A/C On and in heavy street traffic, she will climb into the 200deg F range even still.
Old Jun 12, 2008 | 05:04 PM
'Shifter's Avatar
'Shifter
NCM Member '09
Was any kind of PROM mod needed?
To Am I going to have any problems
