another strange thing lol......
Old Jun 11, 2008 | 02:18 PM
louisjames's Avatar
louisjames
Default another strange thing lol......
ok, my steering wheel has alot of play in it from the pivot where it tilts up and down. is this normal for these cars or it likely to be a loose bolt. im not familiar with the setup on these. thanks
Old Jun 11, 2008 | 03:36 PM
StealthLT4's Avatar
StealthLT4
Mine has some play too. It doesn't really affect anything while I'm driving, so I'm not too concerned about it.
Old Jun 11, 2008 | 04:33 PM
louisjames's Avatar
louisjames
i thought that but my MOT guy said that would normally be a failure. (mot is a yearly certificate/inspection we have to have here to ensure car is road worthy)
Old Jun 11, 2008 | 05:28 PM
SCCA VETTE's Avatar
SCCA VETTE
If you are saying that the wheel can be moved up and down (play) at the tilt pivot then YES the bolts are loose. This is a common problem with GM tilt wheels. there is 4 bolts down in the column that loosen up and need to be removed and lock tite installed and reinstalled.
If it is not bad now I would not be real concerned about it. If it gets worse (really loose wheel) you will need to fix it.
Old Jun 11, 2008 | 07:14 PM
louisjames's Avatar
louisjames
ah. ok thanks for the info
Old Jun 11, 2008 | 10:52 PM
OkieC4's Avatar
OkieC4
Here's a pretty good link about steering column looseness and how to tighten those pesky bolts....
http://www.domesticmisfits.net/forum...cf102df5423ba4
Old Jun 12, 2008 | 03:03 PM
louisjames's Avatar
louisjames
excellent, thanks for the link.
Old Jun 12, 2008 | 04:29 PM
louisjames's Avatar
louisjames
god looks like a horrible job
Old Jun 12, 2008 | 09:19 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
So it's not as loose as you thought ...eh?
Old Jun 13, 2008 | 09:03 AM
louisjames's Avatar
louisjames
lol no i think its ok actually
Old Jun 13, 2008 | 10:06 AM
WW7's Avatar
WW7
Some people use the wheel as leverage when getting out of the car, bad idea, this will screw your wheel up in short order. WW
Old Jun 13, 2008 | 11:45 AM
NEVRL8T's Avatar
NEVRL8T
Old Jun 13, 2008 | 12:02 PM
Can86Z51's Avatar
Can86Z51
Originally Posted by TheAngelOfDeath
Unfortunately, some of us need leverage!!
Old Jun 13, 2008 | 01:52 PM
WW7's Avatar
WW7
Next time you need leverage to get out, hook your foot under the door and use that to pull yourself out . This works great for me and it saves the embarrassment of me having to roll out onto the ground. WW
To another strange thing lol......
