Recomendations for Pump bolt sealant
Old Jun 12, 2008 | 12:30 PM
Klondike's Avatar
Klondike
Default Recomendations for Pump bolt sealant
Changing the water pump over to an electric one. I've got a tube of that right stuff for the front cover, pan & pump housing install. What is the recommended sealer for the water pump bolts that go into the water? Can you use "right stuff" on the threaded areas of the bolts or is there something else?
Old Jun 12, 2008 | 01:08 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I've had good luck with the permatex hi-temp sealant. Comes in a big tube or a small tube, its on the rack at your favorite NAPA store. It was $16 for the big tube (I was doing heads, etc).
Old Jun 12, 2008 | 03:28 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I use Permatex #2 on any bolts into the water jacket and no leaks in over 8yrs.
I prefer Permatex as it's non-hardening, whereas the Right Stuff will take a set and be like a glue...good luck with removing those bolts later.
Old Jun 12, 2008 | 03:39 PM
skybolt31's Avatar
skybolt31
I used medium weight Tite-Seal:
http://www.gunk.com/CAT_T2566.asp
I bought a can for use on my plane on threaded fittings over 20 years ago and has always sealed and I was always able to get fittings and gaskets apart.
There are many good choices, but make sure you use something......
Old Jun 13, 2008 | 12:07 AM
Klondike's Avatar
Klondike
Thanks for the replys. I'm new to "The right stuff" so I didn't know what to expect. I've used some permetex products in the past, so I'll use them again for the wet bolts.
To Recomendations for Pump bolt sealant
