Plugged Cat
Old Jun 25, 2008 | 04:12 PM
DM VETT's Avatar
DM VETT
All of the above. The Cats are fine. After installing new injectors, I went out and punched it and the car flat scared me. Accelaration like you would not belive.
Old Jun 28, 2008 | 11:54 AM
turbotim23's Avatar
turbotim23
So how did you test the injectors? Is there a flow test you can do on car or did you test impedence some how?
Old Jun 29, 2008 | 11:13 AM
DM VETT's Avatar
DM VETT
I checked with an ohm meter. Remove plug and test across the 2 terminals of injectors. Good ones should be 17 -18 ohms. I found 2 that were only 3 ohms.
