Nitrogen In Your Tires
You won 't have to nitrogen up the tires as often.
Let's talk reality. There is little to zero advantage over using plain old free air & it won't cost you perhaps $5 to $7 a tire to fillup either. Some will contend it isn't necessary to fillup but top off at regular intervals. I say Ok if it makes you feel warm & fuzzy have at it.
Cheers
Check your 6
As for daily use, I think it would be a waste. As for moderate track use, MAYBE. Nobody at my local autocross track is using nitrogen that I am aware of. But then again, in autocross you can make a run, then adjust your pressure instead being stuck with it until a tire change like my buddy would be.
Is it a better mouse trap?Yes,however most people won't see the benefit.
how many of us has had a tire fail due to inside deterioration?
I have taken tires off cars I bought that have been on there for 15 years, and the inside looked like brand new, with plain old alabama air in them.
just hype to get people to buy something new they dont really need.
Noland
Noland
I understand that you are speaking chem laws here, but that doesnt help that average person much when making a real world claim about how this idea. Although I have never owned a tire where I would consider its use, i've been around it. My buddy's car has 650hp and it weighs 2900 pounds. One could argue that its actually faster than nascar. On a small 1/3 mile oval, his car could hit 120-130 on the straights. Although he is not a big dog yet, he might be someday. That's where my experience comes from, a few years in THE PITS.
Tire pressure is important factor in how a tire reacts with the road. Racers obsess over details. Nitrogen has it's palce
Now i'm not sure of the humidity of most compressed air sources to fill tires, but if the air is very dry to begin with you dont have to worry about rotting.
N2 has a mole weight of 28.00. Dry Air has mole weight of 28.96 so there is practically no difference in weight in the tires at full PSI. As said, air is 78% nitrogen anyway, and like 21% O2 if i recall correctly and thats part of the reason its a heavier gas than N2 alone
Maintaining inflation duration doesnt make sense to me. Air is 78/21 % N2/O2 which are large molecules. The rest of Air is C02 which is even larger, and Argon which is much bigger/heavier than O2 and N2.
In ANY case, N2 being lighter/smaller than most Air molecules, i would say N2 would leak out much more than AIR!
Someone correct me if i'm wrong, this is my understanding. smaller lighter molecules are harder to keep compressed. Air is larger than N2, so it shouldnt leak as much as pure N2
"Nitrogen Instead of Air
Most of the teams remove the air from the tires and replace it with nitrogen. Compressed nitrogen contains less moisture than compressed air. When the tire heats up, moisture in the tire vaporizes and expands, causing the pressure inside the tire to increase. Even small changes in tire pressure can noticeably affect the handling of the car. By using nitrogen instead of air, the teams have more control over how much the pressure will increase when the tires heat up. "
http://entertainment.howstuffworks.com/nascar5.htm
Say what you want, the big dogs run it. Enough said!
I let them put it in my 84, but i wanted a second opinion before i put it in my 02. I am taking a long trip in a month and thought it might be worth it if there would be any millage gain.
Thanks for all the insight.
