Car weak after hard driving
Thanks!
The time it takes for it to go weak it getting shorter, but it's allways the same. Can't rev more than 3500 rpms and when I'm there the engine is running kind of odd, something is troubling it - it's my best explanation.
I really hope to sort this thing out. I pulled the codes once again the only one was C12 which I can't find and it's probably nothing?
So up to this point I've checked:
- All injectors cold at 15.0 to 15.3 ohms
- Banging on the cats and they are all silent
- Spark plugs look OK
- Left pre cat looks like it's getting warmer than the left one, glowing in the dark
Yes, that's about it I think.
My simple unqualified thought is - could there be a sensor somewhere giving bad readings but not that the ECM know it's wrong?
Thanks!
single wire systems dont do a whole bunch anyway. Especially if they are located in front of the cats
Hook it up to the brake booster, as previously suggested. Note the reading at idle. Now bring it up to a constant 3000-3500 prm while in park. If, after 3-5 minutes at this rpm, the needle starts making its way toward zero you have a restricted exhaust system.
-- Joe
Does this mean my exhaust pipes are clogged somewhere?
Thank you ALL for your help!
