help
Old Jun 14, 2008 | 03:09 PM
byedan's Avatar
byedan
Default help
in my data logs in cell 6, 10, 11,14, and 15 are from 140 to 155 in the same order. at idle the car is perfect at 128. the only thing done to the car is a k and n air filter and a throttle body air foil and a descreened maf i did not descreen the maf so i do not have a screen to repair. also i did not install the air foil. also i have a new msd opti on the car and thought maybe the timing was a little low could this cause the blm;s to be lean?
