'85 Doug Nash 4+3 help!!
Old Jun 14, 2008 | 11:31 PM
Curtis85Vette's Avatar
Curtis85Vette
3rd Gear
Default '85 Doug Nash 4+3 help!!
Okay so basically I have no first or second gear. 3rd, 4th, and reverse are fine. The stick basically moves freely from 1st to 2nd, 2nd to 1st. Like the gears aren't there. This unit has been rebuilt about 20,000km ago. Now this happened when the clutch fluid was low and an individual tried forcing it into 1st...then the stick went ahead and poof
1st to 2nd gone.
Now...did the linkage break somehow? I looked around and everything still seems intact...
PLEASE HELP!! ANY SUGGESTIONS ARE HELPFUL.
Old Jun 14, 2008 | 11:57 PM
Yellow2015's Avatar
Yellow2015
Sounds like a linkage issue. Generally when the doug nash starts to go, you lose reverse. You might have to pull apart the console and look at the shifter rods.
Old Jun 15, 2008 | 12:27 AM
rodj's Avatar
rodj
Had the same.Selector fork inside case came loose from selector shaft .
Lift car , remove 1-2 linkage at side cover and move selector shaft by hand.
If you can't feel it move the parts inside , then shaft is loose.
Requires new selector fork.
From memory ,the round shaft through the case is only pressed/ peened on to the selector fork. Excessive force will break this connection meaning the fork does not move with the shaft
Old Jun 15, 2008 | 03:06 AM
Curtis85Vette
3rd Gear
thanks rodj i'll give it a shot. hopefully thats it. this transmission has been rebuilt 3 times during the course of 5 years! 4+3 = bad!
Old Jun 15, 2008 | 06:07 AM
blaina's Avatar
blaina
3rd Gear
My 4x3 lost reverse I messed around with rebuild kits it's a bit like trying to fix a hole in a boat with a plaster ! I ended up replacing the whole lot with a Tremec 5 speed what a difference its cut a second off the 0 to 60 time and the car is a lot more fun to drive.
Old Jun 15, 2008 | 10:08 AM
c4cruiser's Avatar
c4cruiser
One the car is off the ground, check to see if the bolt that hold the shifter arm to the selector fork shaft is still there or has come loose. If the bolt is there and tight, then you will have to pull the side cover.
Check the 3-4 fork and slider when the cover is off. It would be worth it to replace that fork at the same time.
What part of the tranny have you rebuilt 3 times in 5 years?? The 4-speed portion is actually a Borg-Warner Super T-10 and they are a very strong tranny. Most 4+3 problems show up in the OD unit. Either your rebuilder doesn't have a lot of 4+3 experience or is using cheap parts.
There are some steps in the OD rebuilding process that are critical and have to be done right otherwise there will continue to be problems. This shop is supposed to be a good place to have the 4+3 repaired or get help.
The 4+3 is actually a good tranny and it even handled the power from the 87 and 88 Callaway twin turbo cars. As long as they are properly maintained and used correctly, they work.
To '85 Doug Nash 4+3 help!!
