ignition advice
Old Jun 15, 2008 | 11:11 AM
j-stingray's Avatar
j-stingray
Default ignition advice
well im looking for an ignition upgrade for my 1990 6 speed vette
im leaning towards an msd but witch one wil work with my com/ecm?
any advice guys??
thanks jeff
Old Jun 15, 2008 | 12:50 PM
Aardwolf's Avatar
Aardwolf
Is this for forced induction? If not, stock is fine.
Old Jun 16, 2008 | 04:23 AM
j-stingray's Avatar
j-stingray
no i just want an upgrade of the ignition system and an msd looks nice
,but maybe someone has better experiances with another brand/ignition!??
thank jeff.
Old Jun 16, 2008 | 08:36 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you are at or near stock I would leave it alone.
Old Jun 16, 2008 | 10:32 AM
Deakins's Avatar
Deakins
I haven't had any of the horror stories happen to me with my MSD (it is running on an older set up mind you) so I don't have a problem with them. Many debate any gains and I can see that; where we run the set up is on a 650 hp hot rod engine... The MSD equipment gave us the flexibility that we needed to get it dialed in right.
Old Jun 16, 2008 | 10:57 AM
Aardwolf's Avatar
Aardwolf
thank jeff.
If this is a for looks mod only, you could make a pretend box and not spend a lot of money for no gain in performance. Running a search on MSD here should turn up some pictures and threads on their boxes.
Old Jun 16, 2008 | 11:03 AM
anesthes's Avatar
anesthes
I don't know many stock C4's in the 12s
-- Joe
Old Jun 16, 2008 | 11:07 AM
anesthes's Avatar
anesthes
thank jeff.
I ran a few MSD 6ALs, and a BTM. They all worked fine, one failed but MSD replaced it. The only complaint (other than 30 year old technology) is the 'ticking'.
The mallory hyfire stuff is nice. I ran that on my last supercharged application. On a N/A cammed car there is some benefits at high RPM as the dwell time is very limited vs what is required to charge the coil between firing. If you have a higher compression motor and need a wider gap to light the charge AND high RPM a CDI ignition will keep it from missing up high.
If nothing else, the rev limiter is worth the $200 or whatever those boxes go for these days. I've experimented with the factory rev limiter in the chip and have already exploded one catalytic converter heh.. (literally, ceramics flying out the tailpipe).
-- Joe
Old Jun 16, 2008 | 11:16 AM
BADDUCK's Avatar
BADDUCK
-- Joe
That would very very very few, I don't pay attention to those time sticker avatars, I look for mods and saw none posted. I think I'll put up a 10 second one and really impress ya!
Old Jun 16, 2008 | 12:32 PM
anesthes's Avatar
anesthes
haha, then you'll be like the crossfire guys!
Point noted and agreed.
-- Joe
Old Jun 16, 2008 | 12:58 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Jeff
I am running the stock HEI distributor and an MSD 6AL. Set gap at .035 and you will be all set.
Highly recommend the Taylor 509 SP wires, they are pretty large and hold up for YEARS of abuse.
Also I run NGK plugs and have real good luck with them as well.
That combo should be good for anything you throw at it.
To ignition advice
