Hesitation under heavy acceleration
Old Jun 16, 2008 | 08:19 AM
shamdave's Avatar
shamdave
Default Hesitation under heavy acceleration
I have a 85 with a new trans 160 deg thermo, performance chip. After the motor is hot some times when i accel hard espicialy in a turn the car hesitates (kinda Pluhhs out for a second) and then is fine. It mostly happens in the turns never noticed it in a straight line? any idea?
Old Jun 16, 2008 | 11:36 AM
Da Mail Man's Avatar
Da Mail Man
...how much fuel do you have in the tank?...fill it up to at least 1/2 and try it again....some of the c4's slosh fuel inside the tank which causes the fuel pump to suck air momentarily and that is where you may get your stumble....common problen due to inadequet baffeling inside the fuel tank......
Old Jun 16, 2008 | 11:43 AM
shamdave's Avatar
shamdave
it was under 1/4 this time but i think the last time it was around half Maybe ill get a loan fill it up and try it again
Old Jun 16, 2008 | 11:46 AM
Da Mail Man
.......mine Will, on occasion, do that......good luck..,
To Hesitation under heavy acceleration
