Refinish C4 rims Help
Old Jun 16, 2008 | 08:37 PM
rte203's Avatar
rte203
Default Refinish C4 rims Help
I trying to RE finish a set of 85 C4 rims, I use Aircraft Stipper to Remove the Clear, Does anyone know how to Sand the rims to maintain the factory look. I know i will be using a clear By por 15?
Has anybody done this?
Old Jun 17, 2008 | 12:35 PM
LT1 Rocker's Avatar
LT1 Rocker
Default Rims
I had good results using an orbital sander with fine paper and steel wool for hard to get to areas. Did not have to use remover for the old clear, just sanded it off. The crappy clear I used on it the first time turned opaque. Sold them on ebay!
Old Jun 17, 2008 | 12:59 PM
pletzvet's Avatar
pletzvet
I did mine over the winter - sanded the old clear coat starting at 320 grit and progressing up to 2000. Then, my autobody friends put me on to some really good stuff called Autosol (made in Germany) and it polished the aluminum to a chrome-like finish. This is good stuff - comes in a tube. They also discouraged re-applying any clearcoat for the reasons you just described, plus they said that it is very difficult to keep it on there, with cracking/flaking/and discolouration in the not too distance future. Once polished, maintenance is not a big chore as a quick buff with the Autosol on a yearly basis is all that is needed.
Old Jun 17, 2008 | 01:33 PM
louisjames's Avatar
louisjames
autosol is excellent. i have loads of it and it really makes a brilliant job on most metals. i bought my wheels up like mirrors, used a power mop and autosol. also used it around my engine bay. made the a/c pipes like mirrors too.
Old Jun 17, 2008 | 02:40 PM
pbergmann's Avatar
pbergmann
I belive he wanted to keep the factory look.
On my 89 I stripped mine and was fortunate that all I had to do was rub them with Mothers mag wheel cleaner. I masked off the wheel and painted the inner parts silver. Then the clear coat, I made a major mistake though...I powder coated them clear...the problem the Argent silver discolored some because of the heat needed to cure the powder. they look ok but the discolored silver looks aged.
Old Jun 17, 2008 | 03:27 PM
rte203's Avatar
rte203
Your Correct I kinda wanted to stay with the Factory look, I was hoping someone would have used the Por 15 Catalized Clear, I thought that the catalized would Indicate that it would stay on the rim and maintain the correct color? Does anyone Know what the catilized means?
Old Jun 17, 2008 | 03:28 PM
rte203's Avatar
rte203
THis was the clear i was thinking about using. Has anyone used this stuff? http://www.por15.com/products.asp?dept=6
Old Jun 18, 2008 | 03:07 AM
c4sailor's Avatar
c4sailor
I would think that "catalized" means it's a two part epoxy of some sort. Like Exopy based paints. Imron, etc. The paint is one part and the catalyst is the other. The catalyst makes it "kick off" like fiberglass resin. Just my thoughts. We use epoxy based paints on the boats. Many of the high quality paints today are that way. Very hard, essentially colored epoxy.
Old Jun 18, 2008 | 09:31 AM
pmihaltian's Avatar
pmihaltian
Slingshot
So how did the powder coating hold up in NCRS judging?
Old Jun 18, 2008 | 11:02 AM
rte203's Avatar
rte203
Well I assuming, No one has tried the Por 15 Clear, By the Way, thanks C4 Sailor For you response, Do you Think that product would stay on C4 Rims?
Old Jun 18, 2008 | 08:43 PM
guido7834's Avatar
guido7834
The sanding doesn't harm the aluminum finish of the wheels once the clear coat is removed? I am thinking of doing my 87 stock wheels and just don't want to screw it up.
Old Jun 18, 2008 | 10:21 PM
pletzvet's Avatar
pletzvet
The sanding does not cause any harm to the aluminum, but a cautionary note - if you look really close at the finish of your factory clear coated rims, you will see what appear to be very tiny circular ridges left behind when the rim was being machined. I believe this is the 'factory' look. Of course when you sand down past the clear coat (and if you are sanding, you will) then you begin to remove these little ridges. On the other hand, removing the machine ridges is also part of what gives a nice chrome like finish when the aluminum begins to buff up. Polishing my rims was one of last winter's projects and I'd say that on and off, I probably put about 15-20 hours into the project from start to finish.
Old Jun 18, 2008 | 10:25 PM
rte203's Avatar
rte203
So... I guess this means there really no way to finish without having the wheel machined, That is to maintaine the factory appearence, Correct?
Old Jun 18, 2008 | 11:51 PM
pletzvet's Avatar
pletzvet
I suppose if you used some kind of stripping agent to remove the deteriorated/damaged clear coat, you wouldn't need to do any sanding. The problem with the stripping agent is it will inevidably get onto the painted surfaces (centres and vents) and do the same thing there as it does on the clear coat. I think it might be difficult to find anyone that would re-machine the rims, but perhaps...
Old Jun 19, 2008 | 12:06 AM
kenmack's Avatar
kenmack
Default If the aluminum isn't pitted
Use any brand name water soluble stripper.
Two applications at least.
Take fine steel wool or sos pad to get into corners.
Rinse and clean / sos or steel wool the whole wheel.
Use a strong anti-grease agent (superclean / purple bottle ) works good.
Thoroughly dry (overnight)
Mask off the bulk of the wheel centre.
Warm the wheel before applying prime coat.
Thoroughly dry.
Warm the wheel
Apply finish coat (silver i presume)
Allow to get late stage tacky.
Apply clear coat (light dusting)
Thoroughly dry.
Warm the wheel
Apply final clearcoat(let tack and apply second coat and third).
Thoroughly dry.
Use fine steel wool or sos pad and or rag DAMP with laquer thinner to carefully take paint off polished surfaces.(watch those edges)
Fine steel wool circular with wheel to polish.
Mothers aluminum and lots of elbow grease.
Amazing results!!!!!!!!
Old Jun 19, 2008 | 01:12 AM
c4sailor's Avatar
c4sailor
The epoxy based paint I am most familiar with is Imron. It's a DuPont product. There are others. I think you could go to their web site and pull a spec sheet and find details about application and surfaces that they recommend it for. I know it's been used on metal, fiberglass and carbon based hulls. Your local auto paint store should also have a wealth of information on the subject specific to the automotive lines. FYI - we coat keels with the epoxy "barrier coats", some portion of the keels sit in the water even if the boat is on a lift so they are submerged in water for extended periods of time and subjected to the living creatures of the deep that attach to anything. That's why we use the epoxy - it stands up to the nasty little critters.
Another good source might be to contact the tech people at "Eastwood", their focus is automotive and I've found their tech people to be helpful. They will send you "spray outs" of samples of a particular product/color if you ask.
And, reading Kenmacks post, I think he has the procedure down!
Old Jun 19, 2008 | 12:00 PM
89onlyZ51's Avatar
89onlyZ51
The trouble with aluminum is that within minutes of being exposed to air, a very thing layer of oxidation develops. This is why you would have trouble adhering paint and why attempts at clearcoating turn opaque. I believe the factory process was to machine the wheel, quickly anodize it and then apply the clear coat.
You could probably come close to the factory finish by using a chemical stripper to get the old clear coat off, quickly prep the surface with Alumaprep and Alodine (a chemical anodizing process used on aircraft - Google that for more info), and then re-applying clear coat. I haven't used this stuff on wheels, but I found it necessary to get paint to adhere to my aluminum boat outdrive.
P.S. - never use metallic abrasives (steel wool, wire wheels, etc.) - they will leave behind iron particles embedded in the softer aluminum, and you'll get galvanic corrosion and a nasty finish. always use synthetics on aluminum.
To Refinish C4 rims Help
Old Jun 19, 2008 | 12:14 PM
jhammons01's Avatar
jhammons01
Tif you look really close at the finish of your factory clear coated rims, you will see what appear to be very tiny circular ridges left behind when the rim was being machined.
pletsvet is correct. The way they face the wheel from the factory is with a pointy blade on the lathe. This leaves the ridges that are also described as the "CD" look.
Wheel repair specialist have duplicated this effect for refinishing wheels.
Any Chrome plater has a polishing shop (in the back), they can polish the rim to a shiny luster but the ridges will be gone.
If you want factory looks, you'll have to take the wheels into a (real) wheel repair shop and have them re-cut.
Old Jun 19, 2008 | 12:19 PM
jhammons01's Avatar
jhammons01
That is not true, OP, if you are serious and aren't going cheap, These can resurface our type of wheels on a daily basis
http://www.wheel-repairs.com/
Not only will they repaint the black, resurface the face, re clear coat the whole thing......they will insure that the wheel is rolling true and all the wobble is taken out to a degree that far surpasses factory specs.
(Side note: you should see how crappy brand new factory alloys are on 99% of the cars, You put them on a machine that mounts the same as it does on your hub.......wobble wobble wobble)
Old Jun 19, 2008 | 02:14 PM
jhammons01's Avatar
jhammons01
Originally Posted by 89onlyZ51
The trouble with aluminum is that within minutes of being exposed to air, a very thing layer of oxidation develops. This is why you would have trouble adhering paint and why attempts at clearcoating turn opaque. I believe the factory process was to machine the wheel, quickly anodize it and then apply the clear coat..
your so close.
Yes the Aluminum surface oxidizes immediately.
But now you are talking about surface treatment and Prep. There are techniques for first cleaning the surface (IPA baths etc.) and then organo Silanes used for adhesion to different types of surfaces
http://www.famastechnology.com/pdf/s...69d62e4465d086
These used to be sold under trade names such as "Bulldog"
The opaque in the clear is from cheap clear coat that breaks down under UV light. plus the fact that Clear has no pigment and is a poor barrier, oxygen leaches under it and oxidizes the Aluminum underneath.
