If you have MULTEC injectors WATCH THIS
this shows you how to ohm check your injectors.. do it cold then hot
Thank you for the video; very informative.
I do have a couple of questions for you. In your video, you mentioned that the injectors are off a 1990 vette; are these the original injectors?
If that is the case, you are talking about a car that is 18-years old; how many miles did the car have on it?
What is the typical life span for a Bosch Injector; is there such a thing?
I had over 115K on my 96 before I replaced the entire engine, drove the car extremely hard, and never had an issue with my stock injectors.
I also had a set of Multecs in my new engine and never had a problem with them either. I swapped them out only because I needed a larger lb injector.
Don't get me wrong; I am all for the best products available on the market, will only install the best products on my car (subjective, of course), and it appears that the Bosch Injectors are a great product.
However, I am a bit curious if the problems that you are experiencing would be the same for the Bosch injectors under the same circumstances?
Thanks in advance,
Glenn
Anyone who is considering an injector change would be smart to get them from Jon.
Thanks in advance,
Glenn
Thanks for the quick reply; it definitely seems like you made a great impression with the fellow forum members. Keep up the great customer service.
The next time I am in a market for new injectors; I will definitely give you a call.
Glenn
I can't wait to get the ones for my LT4.
Anyone wondering, don't contemplate it or wait for them to fail and give you headaches. Just call Jon and get hooked up.
Injector coils are low Q coils and the bridge should be set up as a Maxwell bridge which is an inductance bridge meant for low Q coils. You can easily make your own bridge circuit or you can buy an old Heathkit impedance bridge on ebay.
I bought an old General Radio 650 bridge a long time ago to measure capacitors and inductors long before I owned a car with fuel injection, but it came in handy.
OH, watching them spray and measuring their output volume blows the doors off electrical measurents. Thanks for the video!
I put new LS1 injectors in my 87 about 50000 miles ago, so I hope they are good for a while.
