Rpm Fluctuation
Old Jun 18, 2008 | 10:46 AM
ingebrit86's Avatar
ingebrit86
Cruising
Default Rpm Fluctuation
Cruising on the interstate my RPM indicator started bouncing around and performance seemed to drop off. Is this a throttle position sensor problem? 1986 L-98 4+3.........Thanks
Old Jun 18, 2008 | 11:10 AM
rick lambert's Avatar
rick lambert
You can find out by ohming the TPS, directions are in your FSM. You might want to check for vacumn leaks too.
