I remember when I got some Hawk pads that there was a specific procedure such as below taken from their site.
(1) Brake from 50mph down to 10mph using moderate pedal pressure.
Repeat this process 6 to 8 times in succession.
(2) Cool down the brakes by driving for 10-15 minutes on the highway.
Avoid having to use the brakes during this cool-down period.
(3) Repeat step (1), but use very heavy pedal pressure.
Brakes may fade during this set of braking, so please use caution.
(4) Repeat step (2).
(5) Park the car for 4 to 6 hours after the brakes are cooled down.
Allowing the pads to "rest" overnight is preferred.
Cars with a curb weight of over 3000lb. may require one "light" track session to sufficiently heat up the pads, followed by a good cool down period, in order to ensure both pad longevity and maximum potential brake torque
Is this necessary for NAPA Ceramic pads I just bought?
I would imagine that would be the "most perfferd" method of breaking them in, but in reality, about 10 regular pressure stops with some cool down time in between stops, is good enough. The idea is to scrub off some of the top finish of both the rotors and pads to "seat" them together. I don't really think anything that elaborate is going to make or break the pads. ...but if you've got the time, why not do it? It can't hurt.
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Re: Brake pad break-in procedure (Rich B.)
After I installed the NAPA Ceramix pads this summer, I drove it normally for a week with very easy stops. Then I tried a maximum stop from 70 mph, and they did not stop it as quickly as they should have. That must have seated them in as they have stopped extremely well ever since with very little dust appearing on the wheels. I am very happy with the NAPA Ceramix pads but they are pretty expensive.
