thinking about NOS
It doesn't sound like you know a lot about nitrous so you might want to read up on it a bit. There is a long write up about it on my website, www.jkvette.cz28.com. It's long, so only go there if you have time to kill, lol.
To answer your questions, in the order you asked them:
150 is widely considered the upper side of what the engine can handle. Many people have been running 100 and 125 shots for years without issues. Most who try to go over 150 don't make it very far without a failure.
All systems have some kind of activation based on a button. Normally, you will flip a toggle switch inside the car. That will arm the system. Next, when you floor it, there is a switch mounted on the throttle linkage that gets pressed only when the linkage is at wide open throttle. As long as the arming toggle is flipped to on, and this wide open throttle switch is pressed, the system will be spraying.
I'm not sure what you mean by timer, other than maybe a progressive controller. That's not really entry level stuff, but a controller will allow you to bring the nitrous on gradually as opposed to smacking the engine and tires with the entire shot all at once. For example, if you have the 100 HP jets installed, you arm the system, and floor it in first gear, the nitrous system is going to add 100 HP to the engine basically the instant your foot hits the floor. With a progressive controller you can make the system come on over a period of time. So, when you first floor it the nitrous kit may only add 10 HP. Then, over the course of the next 2 seconds, ramp the power up to the systems full capacity of 100.
You don't need to do anything to your engine. You could pull some timing, but the stock timing on the L98 is conservative, so I think you'll be fine on a 100 shot. Run 93 octane and have a good time.
It won't affect your daily driving at all. You'll lose some cargo room for the bottle in the back, but other than that, there is no affect on the normal functionality of the car.
You normal mileage will not suffer. When spraying, you will use a considerable amount of gasoline. It's not like you can watch the gas gauge move or anything, but it will use some fuel.
The solenoids are not designed to stand up to 1000+ PSI from the bottle for days/weeks/months at at a time. That is why you can't leave the bottle open all the time.
A 10 Lb. bottle will normally last me 10 quarter mile runs, with the last 3 runs or so falling off slightly. Roughly one Lb. of nitrous for every 10 seconds of acceleration on a 100 shot.
Never used Zex, but most of the entry level kits are pretty decent. I've head bad things about NOS solenoids, but I've never had a problem with them.
As far as searching, there isn't much to it, especially on this subject. If you scroll to the bottom of the first page of threads, there are 2 or 3 posts very similar to yours.
Yeah, I haven't gotten around to updating it or anything. I guess I could go kill some time on there now.
