any Accel Gen VII wizards here?
Old Jun 19, 2008 | 01:31 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
Default any Accel Gen VII wizards here?
i'm on the C1/C2 forum but it was suggested that i also post my EFI question here. i would appreciate it if you would take the time to read the following thread link and offer advice.
http://forums.corvetteforum.com/show....php?t=2049207
Bill
Old Jun 19, 2008 | 01:47 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Bill, after reading the thread, I wonder if you are focusing your attention in the wrong place. What's going on with the IAC during all this?? If you want to send me a copy of your cal file, I will take a look at it. If so, I will PM my e-mail. In the mean time, try to get a handle on IAC positioning with your data logger.
Bullshark
Old Jun 22, 2008 | 05:21 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
does anyone know how the Accel VE table correlates with injector size?
will a smaller 24# injector flow less fuel than a 30# injector while still using the same 30# VE table values, or will the ECM try to compensate for the smaller injector in order to bring the flow back up to the 30# rate?
Bill
Old Jun 27, 2008 | 10:48 PM
weez58's Avatar
weez58
Bill,
What distributor are you using?
Old Jun 28, 2008 | 10:42 AM
RonRed89's Avatar
RonRed89
Bill
If DFI operates like FAST, you should just have to change your injector constant in the global options page, and the VE table values should be pretty identical.
Ron
Old Jul 7, 2008 | 05:19 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Originally Posted by weez58
Bill,
Accel Dual Sync with tach drive
Bill
Old Jul 7, 2008 | 05:23 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Ron
thanks, i've done that, but i actually had to increase the injector constant to almost 50# in order to get the wide band 'closed loop correction' to run more towards a neutral setting.
still having hot start problems...
Bill
Old Jul 7, 2008 | 08:05 PM
weez58's Avatar
weez58
I asked about your distributor because I was having some strange problems during cranking when I had an MSD tach drive. I switched to the Accel Dual Sync and everything is good now.
Old Jul 7, 2008 | 08:10 PM
weez58's Avatar
weez58
By the way, there is an Accel tech guy that watches the Chevy Talk EFI forum. You may want to post the question there. Do you have a check valve on your fuel pump outlet? I installed the one from Aeromotive, it made my hot starts quicker. It doesn't hold pressure well enough for cold starts.
Old Jul 7, 2008 | 08:26 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
nope, no check valve, i didn't know that there was such a thing...; i do see that the fuel rail pressure bleed down relatively quickly, but i'm not sure that is my problem as the fuel rail pressurizes at each start. i keep thinking i'm getting too much fuel at hot start (i have lowered the starting fuel multiplier as low as it will go..), so all i can figure is maybe there is a pulse width setting or some other software setup problem..
some seem to think too much timing; but i've lowered the cranking timing to 1 degree and, although it starts a bit easier, i'm still having problems
thanks..
Bill
Old Jul 8, 2008 | 01:05 AM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Bill, how old is your Accel Dual Sync distributor? I was over at my friends Performance shop working on setting up a couple of Twin Turbo BB motors last week for a 42 foot offshore runabout. We were experiencing some anomalies and after a witch hunt we were able to find that the new Accel Dual Sync distributors were different. Seems they had a very narrow cam sync window in the dual shutter wheel that triggers the pickups on the circuit board. This resulted in the blue light (cam sync) turning off almost simultaneous with the #1 cylinder crank (red light) trigger. We put in an older model dizzy which had the wider cam window and everything cleared up. My friend was going to call Accel and find out what the story was, but I have not talked to him to get an update. If you are experiencing almost simultaneous blue/red light transition during setup you might want to verify which one you have by removing the circuit board, or maybe looking down the shaft under the circuit board and check the cam window width.
I will let you know what we find out and why the difference.
Bullshark
Old Jul 8, 2008 | 03:55 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
Bullshark
Bob
i can rarely get Accel support to answer my questions, so i'm having to find 'outside' help who've 'been there, done that'....
here's a pic of the shutter wheel in my distributor
Bill
Old Jul 8, 2008 | 08:05 AM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Bill, from the picture it looks like you have the correct older version with the wider cam sync shutter.
Bob
Old Jul 8, 2008 | 08:44 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
Bob
Bob
this is the second distributor i've had, the first one had the sensors come off the bottom of the board and leave me stranded....
i now have a 3rd one as a spare.....
Bill
Old Jul 8, 2008 | 11:58 AM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
This one looks like it has the narrow cam sync window! Do you see the difference?
Bullshark
Old Jul 8, 2008 | 12:56 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Bullshark
Bob
the only way i can see to judge is by comparing the circuit board holddown cam to the wheel and, unfortunately, i don't see the difference.... i do know that when Accel sent me a new one, they said that there was a newer shutter wheel in it. the one i have in the car now is the one i got through Summit as i didn't want to wait for Accel to figure out what they were going to do about replacing the one that came apart.
the only obvious difference i saw between the one i got through Summit and the other 2 is that the pigtail to the circuit board for the Summit one comes out on the firewall side through a keyhole shaped slot (which i prefer) and the 2 from Accel come out from the front side through a grommeted u-shaped slot. all are Accel distributors, i just don't know what their production dates are as there seems to be no numbers/codes on them anywhere.
Bill
Old Jul 8, 2008 | 01:52 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Bill, the two Accel distributors that have the slotted U shaped grommet are the newer configuration. They would have the narrow cam sync window. That window is on the inner shutter circle, with only the one slot.
The older version ( probably the one you got from Summit) has the cheap o-ring grommet and would have a larger window in that inner shutter circle. Not sure what all this means but, I would think it should have some effect on setup?? I have been trying to get through to Accel to ask this question with no success.
Bob
P.S. Just got off the phone and from what Accel told my friend, there should be no issue with the window slot difference. Computer takes care of the sync. I will have to think about this a little???
To any Accel Gen VII wizards here?
Old Jul 8, 2008 | 02:27 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Bob
Bob
NOW i see where you're talking about... as i see it (pun intended...), it's the edge of the standing portion that triggers the sensor, not the slot; so if the 'edge' is in the same place in relationship to the outer ring 'edge', then should be no difference.. BUT, i can't tell in my picture where the other end of the slot is or it's relationship to the outer ring...
Old Jul 8, 2008 | 02:38 PM
weez58's Avatar
weez58
Bill,
I still think this is a distributor issue and not fuel. The symptoms you describe are exactly what I experienced when I was using the MSD distributor. Changing to the Dual Sync fixed it completely for me. You might want to double check the phasing of the distributor. I thought the instructions from Accel were a bit sketchy. It took me a couple of tries to get it right. I also had to flip the rotor 180* to get the tach drive to line up properly. Try posting to the Chevy Talk forum. There's an Accel tech on the EFI forum. Although I suspect he might be on vacation this week.
p.s. I sent you my ecm file.
Bob
Old Jul 8, 2008 | 04:19 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Bill,
Bob
Bob
my replacement distributor was set up & synced in accordance with the instructions and went in exactly the same way/place as the first one, so if i set up the second one wrong, then the first one was also wrong (always a possibility, but i've checked the timing several times by forcing the timing to 20 & 30 and also verifying it 'unforced' against the dashboard; i don't know what else there is to check).
i looked at the Chevy Talk forum and there are an incredible number of postings on there (probably as many in a month as we have in the C1/C2 forum in many months). i haven't had much luck with getting any help directly from Accel, so i'm not sure what a forum Accel guy would do; besides, you can't post for free like you can here (call me cheap, but i've already put a ton of $$$ into this...), and i didn't see any threads similar to mine problem on there.
Bill
