The door panels look a little different, but they will work fine.
The only thing that I don't know if it'll work or not is the pass side of the console.
Instead of ripping the carpet off of the old consoles and trying to reglue it, just unbolt the console sides and replace them. I did this on my '94 when I changed the interior from gray to torch red/black.
Took me a couple of days to tear out my complete interior and replace it. I took my time and did a little custom stereo install at the same time so that everything was hidden under the carpet.
Get a box of small ziplock bags and a sharpie. Lable all of the bolts and screws, so that you will know where they all go back. There are a lot of them. None of it is hard if you take your time though, and if you aren't sure about how to take something off, just ask. zbra@bellsouth.net
:seeya
You mean I was suppose to label my bolts and stuff for my interior... :eek:
LOL
Most of the stuff should work from the 95 to the 91.. Not sure of the dash pad.. If you do get the dash pad to work.. can I buy your 91 dash pad?
