1990 Dash
Old Jun 20, 2008 | 02:53 AM
Sweet 90's Avatar
Sweet 90
Default 1990 Dash
I have a smudge on the inside of the clear lens cover right in front of the tach. It is really starting to bother me. Is it a PITA to get this piece off and clean it?
Jim
Old Jun 20, 2008 | 08:08 AM
louisjames's Avatar
louisjames
yes! a total pita. i cracked mine trying to get the whole thing out. although if you have a very small socket you can remove just the plastic cover fairly easily. but it is a pain. it gets caught on the collar or tilt part of steering wheel.
Old Jun 20, 2008 | 10:02 PM
Dads90's Avatar
Dads90
It would take you about 3-4 hours to disassemble and reassemble. It's a process starting from the shifter bezel, radio bezel, lower carpeted kick panel, metal kick panel, DIC, instrument cluster bezel, drop steering column, and (can't remember if the headlight switch came off) the instrument cluster slides right out.
Sweet 90's Avatar
Sweet 90
Thanks Louis, I figured as much. Cheers mate
Jim
Old Jun 21, 2008 | 12:27 AM
Sweet 90's Avatar
Sweet 90
Is that all? Gee I thought it was going to be
complicated
Old Jun 21, 2008 | 09:35 AM
93_vette's Avatar
93_vette
It wasn't that bad in my 93. I removed the carpet panel, the metal panel, dropped the steering column (2 bolts), then removed the dash cluster.
Marlon
To 1990 Dash
