L98 failed emissions high CO Help !!
Old Jun 21, 2008 | 10:25 AM
Dads90's Avatar
Dads90
Default L98 failed emissions high CO Help !!
The unthinkable has happened. My beautiful, spotless, 90 just failed emissions. The CO standard at 15mph is .86 I'm at 1.46, at 25mph .94 I'm at 1.55. I just drove the car there, haven't driven it much this week. Any sugsestions ?
Old Jun 21, 2008 | 10:27 AM
Yellow2015's Avatar
Yellow2015
I never bring my car in "cold" Take it on the highway and run it like you stole it for 15 minutes.............
Old Jun 21, 2008 | 11:46 AM
black_89_vette's Avatar
black_89_vette
I run it hot, and I also unplug the ESC wire so the car just runs on it's base timing of like 6 degrees.
Old Jun 21, 2008 | 11:49 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
sounds like you have a vacuum leak or old spark plug wires or it wasn't hot enough, or a lazy oxygen sensor
Old Jun 21, 2008 | 02:30 PM
larryfs's Avatar
larryfs
injectors
Old Jun 21, 2008 | 03:11 PM
SunCr's Avatar
SunCr
It didn't need to have the bejesus run out of it when it was new to pass and if it's right, it shouldn't now. The high CO usually means it's getting too much fuel and scanning it would confirm or rule that out. Assuming you rule it out, it'll need a new CAT. If confirmed, you need to troubleshoot why it's delivering too much gas. So get yourself a scanner so that you can see what it's doing and then post the results. That will eliminate the guesswork or the replacement of good parts - though I have to admit it's sometimes nice to have spares. Otherwise, take the collective guesses and flip a coin as to which one you want to try first.
Old Jun 21, 2008 | 03:18 PM
Dads90's Avatar
Dads90
OK, my first thoughts were correct. The inspector lady couldn't get the parking brake off, the hood open. So I stood there and watched her. The RPM cable, she connected to the throttle cable. I mentioned that, and since I couldn't see from my side of the red line she connected it to number three instead of number one. The whole time the car wasn't running. There were online problems, purging problems, everything was stacked against me. Finally after 30 minutes she started it up and the RPM's were wrong, disconnected and bypassed. She ran it thru the gears like crazy and was in 4th gear for the 25 mph test. Hell the car was hardly running. Thanks to everyone for advice, I ran it hard and on the freeway and went back and their machine was down. Pitched a fit and got my money back, went down the street and the old guy says" It need to be hot". BINGO. Thanks to all.
Old Jun 21, 2008 | 03:26 PM
Yellow2015's Avatar
Yellow2015
Old Jun 21, 2008 | 04:15 PM
Benny42's Avatar
Benny42
Don't unplug the esc connector for the test. The "check engine" light
is automatic fail in compliance counties in Texas. benny
To L98 failed emissions high CO Help !!
