Changing a tail light
Old Jun 22, 2008 | 04:32 PM
murraydeluxxxe's Avatar
murraydeluxxxe
Default Changing a tail light
Does anyone know how to change a taillight on a C4? I'm trying change one an '88. Thanks.
Old Jun 22, 2008 | 04:49 PM
jan-erik's Avatar
jan-erik
Take off the licence plate and the backing lights and go in from there and turn the socket counter clockwise to get them out
JackDidley's Avatar
JackDidley
Remove the license plate, the back up light and reach in with a 10mm socket on a 1/4 drive ratchet and remove the 2 bolts that hold the light in place. When you are done you may need band aides or if you have fat hands you will need some help from a 12 year old.
Old Jun 22, 2008 | 06:00 PM
OldCorvetteFan's Avatar
OldCorvetteFan
That's what I did on my '95.
If you take out the 10mm nuts, does that release the entire assembly (bulb & lens)?
Steven
Old Jun 22, 2008 | 06:04 PM
cjdietzman's Avatar
cjdietzman
By they way, it helps to have thin arms. I am a big guy...I could not fit my arm in as far as needed to replace the bulb. My wife was able to stick her whole arm right in there and remove/replace the bulbs no problem. Every C4 should come with a skinny wife to help with this type of work. hehehe.
To Changing a tail light
