'94 Cold Starting Problems
Old Jun 24, 2008 | 10:51 AM
DeanRM's Avatar
DeanRM
7th Gear
Default '94 Cold Starting Problems
I have a '94 LT1 6-spd, and it starts hard after sitting for a few hours. It will start right up after it has been running.
I checked the fuel pressure, and that is over 40 psi while running, and it will hold the pressure after I shut it down for at least 30 minutes.
The engine cranks over real fast for about 10 seconds before it will fire, then it stumbles a little, then smooths out and runs great. Sometimes I can smell gas a little while cranking.
Any suggestions?
Thanks!
Old Jun 24, 2008 | 12:11 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Any suggestions?
Thanks!
sounds like you have to do more leakdown checks. You say it holds for how long after shutdown? It will probablly always start when the is pressure in the rail. Check that. When there is little pressure does it then start hard? If so, you have and injector or the FPR leaking.. Isolate the leakdown and post further info.
Old Jun 25, 2008 | 09:02 AM
DeanRM's Avatar
DeanRM
7th Gear
Ok, I did a leak-down test last night. As soon as you shut it off, it is about 38 lbs. After 30 minutes, it is 15 lbs. After an hour, it was about 8 lbs.
It starts hard when there is little pressure. How do I check the injectors and the fuel pressure regulator?
Thanks!
Old Jun 25, 2008 | 09:37 AM
94z07fx3's Avatar
94z07fx3
You can hear them fire with a mechanic’s stethoscope. You can verify they are getting a pulse with a noid light. You can see the magnitude and duration of the pulse with an oscilloscope.
A simple test is to remove the vacuum line to it, carry it away from the car, and sniff for gas. A strong smell of gas or visible wet gas is a likely sign of a failed FPR diaphram.
Another test is to watch fuel pressure and RPMs together. Fuel pressure should rise with RPMs.
Old Jun 25, 2008 | 10:04 AM
FICINJECTORS
Supporting Vendor
1st do the sniff test on the vac hose from the reg. But, a regulator could be leaking through the valve inside to release pressure. The hose test is for when you have a torn diaphram. You can check your injectors on an LT1 pretty easy. first clean the manifolf where each injector seats. next remove the pressure (if any) from the rail by pushing in the schrader valve. Then remove the 4 bolts that hold the fuel rail to the manifold. Lift the rail with the injectors out of the manifold and hold the rail high enough to visually see the bottom of the injectors. Now have someone turn the key to on and pressurize the rail. DO NOT CRANK THE ENGINE. If an injector is leaking you will see it drip. A slight drip is all you need to release rail pressure. Your pressure is not droping fast so take your time. Usually a bad FPR diaphram will leak quickly. This whole thing takes a half hour.
If the injectors dont leak. lube the bottom o rings and reinstall in the manifold. start looking at the fuel pump and regulator.
Old Jun 25, 2008 | 10:20 AM
DeanRM's Avatar
DeanRM
7th Gear
Thanks alot guy's. I will work on this tonight and let you know what I come up with.
Old Jun 25, 2008 | 10:31 AM
94z07fx3's Avatar
94z07fx3
Originally Posted by FICINJECTORS
...lube the bottom o rings...
What lube do you use for nitrile (Buna-N) o-rings?
What lube do you use for Viton o-rings?
Old Jun 25, 2008 | 11:11 AM
FICINJECTORS
Supporting Vendor
i use dish soap (palmolive) on all the rings.. soap does not leave any residue on the o ring. Just a preference. Viton can withstand any lube, Buna will dry up using lubes with certain chemicals. so stick with the soap.
Old Jun 26, 2008 | 08:30 AM
DeanRM's Avatar
DeanRM
7th Gear
Guys, I removed the vacuum line off the fuel pressure regulator, and gas ran out.
Does this definately mean that I need a new regulator?
Thanks!
Old Jun 27, 2008 | 02:30 PM
FICINJECTORS
Supporting Vendor
Thanks!
I THINK YOU BETTER REPLACE THAT ASAP. YOU CAN BUY A REBUILD KIT ALSO FROM NAPA FOR ABOUT 49 BUCKS.. JUST A DIAPHRAM..
To '94 Cold Starting Problems
