Taking off the C-Beam. Questions
Anyone know of any tips, comments, advice, etc, etc?
Should I drive the rear up on ramps or the front?
I know that I should support the trans with a jack and take off the bolts for the "C" beam. Is it necessary to take off the DS? I just had the DS balanced so I think that I will mark where it sits so I can replace it the way it came off.
TIA
After shifting into neutral, unbolt the 2 driveshaft straps and four 8mm head bolts connected to the yoke. To access the bolts either turn the wheels or the driveshaft until the bolts are easily accessible.
Then remove the 2 long bolts from the differential and the 2 long ones at the rear of the transmission. Remove the driveshaft by pushing it into the rear of the tranny - it does not require much force. The driveshaft will slip out and then the c-beam will too. The c-beam can be heavier than you expect if you've never held it in your hands before (and if you're on your back). Reinstallation is reverse of removal. Check out the recommended distance from the tunnel top and right side of the tunnel at http://www.zfdoc.com/c4beamplate.htm (scroll all the way down). Buy some plates if you have the money.
Good luck,
Jonathan
I think I will try to drill the holes first. Not sure why they weren't there in the first place on a stick car. Maybe they hook up at different places. They were drilled on the auto "C" beam
I will do this first and then later on I can remove it to do the plates.
I've not used one in quite some time and I don't have or never had an '86 - '91 MY car so I don't know the clearance issue at this bracket BUT I've used some very "compact" right angle drill adapters. I wouldn't think the bolt could be any larger than 8mm so I'd consider a right angle adapter from a tool rental maybe and "shorten up a drill bit"!.
I just checked three c-beams I've got and none have a provision for the hanger I just described or best of recollection is on the L98 cars. One has four holes 6-8" or so rearward of the trans mounting bolts in both the top and bottom of the c-beam maybe on 2" centers. If these are the ones you're referring to it looks like it's time for the c-beam to come out or if you're real talented and can maneuver the drive shaft out with the beam in the car you might pull it off! I've heard people mention they've done it, I haven't!
1.
In this photo you can see the bracket that is attached via two bolts to the C-beam. It attaches to the rubber mount pictured in #3 which attaches to the hanger welded to the exhaust in #4 (note that the pic in #4 is from a Corsa exhaust and not a stock exhaust).
2.
Here is the opposite side of the c-beam.
3.
The rubber mount.
4.
The exhaust hanger on the exhaust. NOT a stock exhaust (Corsa).
5.
The transmission extension housing. The two holes in the lower right corner are affixed to the cat. heat shield/hanger in pictures 6 and 7 via two bolts.
6.
The cat. heat shield/exhaust hanger.
7.
Another picture of the hanger/heat shield. Note that the two bolts in the hanger are attached with two SQUARE nuts. I broke off the right bolt because I was not aware of it. Use a screw driver and wedge it in between the outer heat shield and the square nut. All of this is tough to see from below!
Good luck and hope this clarifies something,
Jonathan
1.
Jonathan
C beam can be removed with DS in place .
My '87 with D44 had exh hanger.
