Door Sill Carpet Replacement?
Jun 26, 2008 | 02:26 AM
St. Jude Donor '06-'07
Has anyone replaced the carpet on the door sills of a '90-'96? I will be replacing the carpet in my car, and was wondering how hard is was to do. I have new front speaker covers that I removed the cloth/carpet from, that was pretty easy, but the door sill looks much more difficult. Any tips would be appreciated.
Randy
Jun 26, 2008 | 07:56 AM
they are easy, undoo the plastic peice near door catch (2 screws) then undo the 2 screws in the carpet on sides, then whole thing lifts up and out.
Jun 26, 2008 | 10:40 AM
OK, maybe I did not make my self clear, I know how to remove them from the car, I need to know if anyone has removed/replaced the carpet from the plastic? And how it was done it?
Jun 26, 2008 | 10:54 AM
its glued on to plastic. i would just re glue.
Jun 26, 2008 | 01:31 PM
The problem is removing the old carpet. I was wondering if anyone had done this?
Jun 26, 2008 | 02:38 PM
yes its glued on, remove the rubber surround and just peel it off.
Jun 26, 2008 | 02:48 PM
C4 of Year Winner (appearance mods) 2019
Quote:
Originally Posted by
louisjames
If they won't peel easily enough, try placing in the sun on a hot afternoon. The heat should help soften old glue.
Jun 26, 2008 | 03:22 PM
GREGGPENN
ps: yours wheels are sexual!
Jun 26, 2008 | 06:31 PM
RandyJ75
It's a PIA for sure. Bear in mind though that the replacement carpet is larger to allow for trimming.
Jun 27, 2008 | 01:48 AM
GREGGPENN
Anyone use a heat gun? would that work, or would it create too much heat?
