Help Please! Another IAC Question.
Old Jun 27, 2008 | 10:05 AM
1bigjim's Avatar
1bigjim
Default Help Please! Another IAC Question.
When you ground out the diagnostic link I can hear the IAC motor running. I waited 30 seconds and it is still running. So my question is, will it keep running until I shut off the ignition key or unplug the IAC?
Old Jun 27, 2008 | 11:30 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When you short ALDL pins A&B and turn On the key, the ECM will drive the IAC pintel to its full extended position. Since this is an "open loop" (i.e. no feed-back to the ECM) operation, I suspect that the IAC motor does keep running till you turn the key Off or pull the IAC plug.
Old Jun 27, 2008 | 12:31 PM
1bigjim's Avatar
1bigjim
Thanks, that makes sense. I just thought it worked on a worm gear and why would it keep running.
To Help Please! Another IAC Question.
