Is it easy to pull the engine and transmission together on an '89 with auto?
I have pulled one or the other but not both at the same time. If it's possible, is there anything special that needs to be done? I presume that removing the hood is necessary.
I made some nice 10" blocks, remove the hood, drop the exhaust, I remove all the accy drive, be sure to plug the tailshaft , remive the tranny lines and it is helpful if you have a adjustable hoist chain. Also your lift will nee to be tall enough to get the engine and tranny out at an angle.
