Melling "Select" 10552 pump
Old Jun 28, 2008 | 06:33 AM
WVZR-1's Avatar
WVZR-1
Default Melling "Select" 10552 pump
Is anyone using presently a Melling 10552 "select" pump in a stock oil pan or a pan with similar depth?
I'm interested in a pick-up that you might have used for this pump/pan confuguration. The 10552 has provisions for a "bolt-on" pick-up and if a pressed pick-up were used it needs to be substantially larger than the .626 on the OE pumps.
Thanks,
-Dave
See also my WTB for: 2 - 9.5 X 17 "Factory Reproduction" black 5-spokes
Old Jun 28, 2008 | 08:21 AM
rodj's Avatar
rodj
Might be useful
http://forums.corvetteforum.com/show....php?t=1900825
Old Jun 28, 2008 | 11:23 AM
WVZR-1's Avatar
WVZR-1
"rodj" - thanks, I found enough there to head me in a different direction!
I had searched but ended up with more of the "issues" than "solutions" with the newer product! I just assumed if someone has/is using with a stock pan etc I might only have to check a single solution.
To Melling "Select" 10552 pump
