steering wheel shake
Old Jun 28, 2008 | 03:59 PM
BRWK's Avatar
BRWK
Default steering wheel shake
My steering wheel shakes between 59-62 mph ONLY when the top is off. Similar to the front tires needing balanced. Top on, no issues. 94 LT1. Whats up?
Thanks,
Brian
Old Jun 28, 2008 | 04:09 PM
rfn026's Avatar
rfn026
It sounds as if you have a tire balance issue. An out of balance tire will only cause a vibration at a given speed. The car is fine below that speed and is fine over that speed.
If you had a steering/suspension issue the vibration would get progressively worse as you increased the speed of the car.
Richard Newton
101 Projects for Your Corvette 1984-1996
Wheel and Tire Performance Handbook
Old Jun 28, 2008 | 05:06 PM
aminnich's Avatar
aminnich
everything is much, much more noticeable with the Targa off. Sorta like suddenly driving a wet noodle.
Old Jun 28, 2008 | 07:08 PM
BRWK's Avatar
BRWK
Thanks, didnt think it would be balance since it goes away when the top was on. So I guess its a little out of balance and the top just multiples the issue. Cool....and thanks again.
To steering wheel shake
