My vents wont changer over from the floor to the the dash or to defrost. its stuck on the floor vent. Whats the probable cuase. its not the switch i dont thing becuase the little light that tells you what setting it is on changes when you push the different buttons just not the actual difference in vents. thanks
Try the cheap fix first - there's a vacuum check valve under the passenger side fuel rail cover - you can get a replacement for a couple of bucks. Looks like this:
ok the check valve had a hole in it. good call guys. But where can i get a check valve at? i just put a T in there for now that wont hurt anything for short drives will it?
